I have a set of computers loading Ubuntu from a PXE server. I'm changing base image and in the new one I need to pass a kernel parameter to the OS (this one: amdgpu.vm_fragment_size=9).
During testing I put it in the GRUB_CMDLINE_LINUX_DEFAULT variable in /etc/default/grub and run update-grub, like you do, but now I'm booting from the PXE server, so I can't do that.
This is my pxelinux.cfg file:
DEFAULT ubuntu
LABEL ubuntu
KERNEL /vmlinux-4.8.17-040817-generic
APPEND ip=dhcp rw root=/dev/nfs nfsroot=192.168.1.254:/diskless/ubuntu/0185 raid=noautodetect quiet splash
INITRD /initrd.img-4.8.17-040817-generic
I tried to add the variable at the end of the APPEND line, it looks like this now:
DEFAULT ubuntu
LABEL ubuntu
APPEND ip=dhcp rw root=/dev/nfs nfsroot=192.168.1.254:/diskless/ubuntu/0185 raid=noautodetect quiet splash amdgpu.vm_fragment_size=9
And I used /etc/init.d/nfs restart to apply the changes, but it didn't work. I also tried the method described in this answer, it didn't work.
I should also say that this is my first time using a PXE server and/or NSF, so I might be missing something basic, any help is appreciated.
Fyde
  • 41
The first method I showed is actually correct, I just forgot to load the right kernel. Everything is working fine now.
Fyde
  • 41
