this wifi adapter used to work really nicely on my Ubuntu workstation when I was in 16.10 using this fixed driver : https://github.com/pvaret/rtl8192cu-fixes.git
After some upgrade (probably the upgrade from 16.10 to 17.04), it stopped working, even after correcting the "random MAC address" bug in NetworkManager.conf with :
[device]
wifi.scan-rand-mac-address=no
So I fully uninstalled the fix (now deprecated), but it's still not working.
Here is the driver now in use :
$ sudo lshw -C network
      configuration: broadcast=yes driver=rtl8192cu driverversion=4.13.0-25-generic firmware=N/A ip=192.168.10.36 link=yes multicast=yes wireless=IEEE 802.11
To be more precise, I can see wifi networks, I can connect to one, but then I can't reach anything. Some pingable IP from wired network are not pingable, so it's not (not only ?) about DNS conf (example : "ping 86.79.27.49").
What should I try from here ?
See comment, the "duplicate" question is not about the same adapter.
EDIT : some logs and tests.
$ dmesg | grep rtl
[    7.173625] usb 1-6: rtl8xxxu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[    8.130550] usbcore: registered new interface driver rtl8xxxu
[    8.159267] rtl8xxxu 1-6:1.0 wlx74da385dfd3e: renamed from wlan0
I can't ping 8.8.8.8 wireless with this machine on this Wifi network, but on my other machine (windows 7) connected to the same Wifi network, I can. And about name resolution, it's a step further I think, and no it doesn't work.
Tristan
  • 103
From our lengthy discussions in chat, it was found that you had some settings in /etc/resolv.conf, some partial settings in /etc/network/interfaces but still relied on Network Manager to connect with wireless.
Network Manager generally is designed to completely ignore any interfaces that are declared in /etc/network/interfaces. It is therefore preferable to use one method or the other, but not a combination of both.
I recommended that you reset both files to their defaults and rely on Network Manager entirely. You have some unique DNS nameserver settings that are required for ethernet and we also set those in Network Manager.
After making the suggested changes, detaching the ethernet cable and rebooting, the wireless is now working as expected.
chili555
  • 61,330
