23
I received the updates through normal Software Updater, 10-Jan-2018. After this VirtualBox would not start any VM, complaining about dkms and asking to make modprobe vboxdrv. Following the advice I reinstalled virtualbox-dkms with:
sudo apt-get --reinstall install virtualbox-dkms
After this and a reboot I tried to start a VM which freezed the whole machine and a hard reboot was necessary.
Is there a way to make VirtualBox work with the latest kernels?
EDIT:
As suggested by N0rbert, the command:
apt-cache policy `dpkg -S VirtualBox | head -n1 | sed -e 's/://g' | awk '{print $1}'`
gives:
virtualbox-qt:
  Installed: 5.0.40-dfsg-0ubuntu1.16.04.2
  Candidate: 5.0.40-dfsg-0ubuntu1.16.04.2
  Version table:
 *** 5.0.40-dfsg-0ubuntu1.16.04.2 500
        500 http://fr.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages
        100 /var/lib/dpkg/status
     5.0.18-dfsg-2build1 500
        500 http://fr.archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages
EDIT (on 29-Mar-2018): Issue is resolved for me, with the Ubuntu Ubdate from today. I have seen that it had some virtualbox-updates, therefore I tried to boot with the most recent kernel again. Then I had to run
And after this my virtual machines in VirtualBox started working without crashing the whole computer. Finally!
Upgrading to VirtualBox 5.2 using oracle repository worked for me.
Here are the steps (legacy doc here):
1) Add oracle repository :
sudo add-apt-repository "deb http://download.virtualbox.org/virtualbox/debian xenial contrib"
Modify this command to suit your ubuntu version if you are not using Ubuntu 16.04 (xenial).
2) Add GPG keys for repository :
wget -q https://www.virtualbox.org/download/oracle_vbox_2016.asc -O- | sudo apt-key add -
wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | sudo apt-key add -
3) Check GPG keys :
sudo apt-key finger Oracle
should give show the following fingerprints :
B9F8 D658 297A F3EF C18D  5CDF A2F6 83C5 2980 AECF
Oracle Corporation (VirtualBox archive signing key)
7B0F AB3A 13B9 0743 5925  D9C9 5442 2A4B 98AB 5139
4) Install VirtualBox 5.2
sudo apt update && sudo apt install virtualbox-5.2
In my case I had errors and I had to remove virtualbox-dkms package and run /sbin/vboxconfig :
sudo apt remove --purge virtualbox-dkms
sudo  /sbin/vboxconfig
Depending on your desktop environment, the launcher menu icon may have disappeared. In that case, recreate it manually; the command is simply virtualbox.
user149408
  • 1,453
  • 15
  • 30
Max
  • 644
Cross referencing:
Official bug tracking this issue is:
https://bugs.launchpad.net/bugs/1736116
There are solutions there for installing VB 5.1.30 as well as 5.2.4. Some users are reporting QT dependency issues with 5.2.4, so 5.1.30 might be a safer bet.
Several options for installing either version are listed there, and the discussion is ongoing, so I am not going to reproduce here.
When you boot your machine change which kernel you boot into by going into "Advanced options for Ubuntu".
Pick the version number like 4.10 -- Should start working until this gets fixed.
wjandrea
  • 14,504
therefriedbean
  • 349
So, in my case, the kernel modules were not removed properly.
Here are the details:
root@Dell5280 [~]# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.3 LTS
root@Dell5280 [~]# uname -r
4.13.0-31-generic
Problem:
root@Dell5280 [~]# modinfo vboxdrv
filename: /lib/modules/4.13.0-31-generic/updates/dkms/vboxdrv.ko
version: 5.0.40_Ubuntu r115130 (0x00240000)
license: GPL
description: Oracle VM VirtualBox Support Driver
author: Oracle Corporation
srcversion: 6D8B4900A693FC50489A130
depends:
vermagic: 4.13.0-31-generic SMP mod_unload
FIX:
root@Dell5280 [~]# rm /lib/modules/4.13.0-31-generic/updates/dkms/vboxdrv.ko
modinfo: ERROR: could not get modinfo from 'vboxdrv': No such file or directory
[1] root@Dell5280 [~]# /sbin/vboxconfig
vboxdrv.sh: Stopping VirtualBox services.
vboxdrv.sh: Building VirtualBox kernel modules.
vboxdrv.sh: Starting VirtualBox services.
filename: /lib/modules/4.13.0-31-generic/misc/vboxdrv.ko
version: 5.2.7 r120349 (0x00290000)
license: GPL
srcversion: 4880B21EFF1B605D6402982
depends:
parm: force_async_tsc:force the asynchronous TSC mode (int)
After this, everything works (at least in my case)
Hope it helps.
I posted the reply at https://bugs.launchpad.net/ubuntu/+source/virtualbox/+bug/1736116
Andy
  • 393
