I do not see the option to install Ubuntu alongside Windows in the installer.
nixpower
  • 1,230
  • 19
it seems like your windows is not genuine. No problem if you have a unallocated space in your hard disk you can dual boot your system by selecting
something else > (continue) > free space > (+) > use as > Swap Area > (enter the size) (max it should be the size of your RAM or 2x of your RAM) (don't change any thing apart from these) > (OK) > free space > (+) > mount > select ->( / ) (first option) (apart from this don't change any thing if you want you can change the size of disk) > (OK) > (select newly created partition) > (install now).
hope this will work for you.
Thank you.
