I have tried a machine with Ubuntu 16.04 32- and 64-bit and Ubuntu 17.10 64-bit several times. Intel Virtualisation is enabled in BIOS. Secure boot is disabled. It happens on kernels 4.13.0-26-generic and 4.13.0-31-generic. Maybe it has something to do with the fact that I installed and purged gnome-boxes earlier. An example of a consequence of that is that a system user Libvirt Qemu still appears on the login screen and I am afraid that removing it might break something. Interestingly, VirtualBox seemed to work well when I installed it inside an Ubuntu 16.04 virtual machine in the aforementioned gnome-boxes although unsurprisingly the machines run by it were very slow.
geras
  • 476
5 Answers5
I had the same Problem after upgrading my Kernel to 4.13.0-26-generic I selected my previous Kernel 4.10.0-42-generic in grub on boot time and it worked.
My guess is that there is a problem in the most recent Kernel. (4.13.0-26 at the time of this writing) Problem is, that is the one with a Patch for the vulnerability CVE-2017-5754 (Meltdown).
Same here, solved by installing Virtualbox 5.1.30 from the website.
This happened to me too. I had to install Virtual Box 5.2.6 and after that I had no problem running vms. However, I did have an issue with Virtual Box 5.2.6 and my iwlwifi driver on my laptop. The computer would just randomly hang. Took me a few days to figure out. Had no problem with other wifi adapter using other drivers. There was an issue with kernel 4.14 with Virtual Box 5.2.6 and iwlwifi. I had no issues prior to the new kernel with the older version of VB
JesseMP
You can solve this by installing a lower version of virtualbox or the latest version of vmware, or still, downgrade your kernel.
From https://superuser.com/questions/1284924/virtualbox-freezes-my-host-system-ubuntu-16-04/1305277#1305277 :
This seems to be Bug #1736116 "[SRU] Host with kernel 4.13 freezes when starting a VM with VirtualBox"
There is now a fix in the virtualbox packages version 5.1.34, available in the in the xenial-proposed repository, and hopefully soon in the main repository.
For a quick copy/paste solution, this worked for me:
echo "deb http://archive.ubuntu.com/ubuntu/ xenial-proposed restricted main multiverse universe" \
| sudo tee -a /etc/apt/sources.list.d/ubuntu-proposed.list
echo "Package: *"                     | sudo tee -a /etc/apt/preferences.d/proposed-updates
echo "Pin: release a=xenial-proposed" | sudo tee -a /etc/apt/preferences.d/proposed-updates
echo "Pin-Priority: 400"              | sudo tee -a /etc/apt/preferences.d/proposed-updates
sudo apt update
sudo apt-get -t xenial-proposed install virtualbox virtualbox-dkms virtualbox-guest-additions-iso
Once the packages are moved from xenial-proposed to the main repository, you can
sudo rm /etc/apt/sources.list.d/ubuntu-proposed.list /etc/apt/preferences.d/proposed-updates
mivk
  • 5,811
