If we are installing Ubuntu by flash drive can we generate the flashdrive with poweriso in another laptop?
Yes of course you can generate the flash drive using Power iso. If you are using windows os in that laptop then download the poweriso in windows Select image file(.iso) of ubuntu . Select the disk you are using for booting. Then burn it .. If you are using ubuntu in another laptop then Use startup disk creator which is system application provided by ubuntu.. .. You can use 1.universal usb installer 2.rufus 3.winusb
Softwares for making flash drive in windows
Hope it will help you
