I've always used Windows as an operating system, which is not a surprise, but recently, I've seen a really good deal for a Desktop PC, the only downfall in my case was that it came with Ubuntu pre-installed. I did my research before buying and saw that Ubuntu offers a lot of benefits, and I really wanted to try something new out and well, here I am!
A partition-installation pops up and no options, only 2 partitions I could choose from, one with around 10GB which was allocated for the system I suppose and 990GB for myself, but... no resizing, editing, adding options, the only button I could press was Forward, came with an error that GRUB failed to be installed on any on the partitions and went on. Excited, I started doing all the first boot-up stuff, updates and such, and after all was finished, I went on to try out a game to see how the PC feels, and went on to install Steam, only for the system to say that I have no space left, even though I should have an untouched partition with 990GB left.
And now I am unable to even download another version of Ubuntu to put on a USB stick to reinstall, and on the Disks app it says Filesystem Partition 2 8.0GB Ext4 /dev/sda2 mounted at Filesystem Root and the other partition which the PC sees it as an external hard drive since I can just eject it, and I can mount and unmount it at any time, regardless of which type I use, I simply can't use that space.
Now I have no space to do anything.
Here's what the df -h command shows:
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 0 3,9G 0% /dev
tmpfs 785M 9,5M 776M 2% /run
/dev/sda2 7,3G 6,9G 576K 100% /
tmpfs 3,9G 26M 3,9G 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 785M 64K 785M 1% /run/user/1000
/home/lightriphy/.Private 7,3G 6,9G 576K 100% /home/lightriphy
This is the lsblk command information:
lightriphy@Lightriphy-HQ:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931,5G 0 disk
└─sda2 8:2 0 7,5G 0 part /
sr0 11:0 1 3,5G 0 rom
And this is the sudo parted -l command information:
Model: ATA ST1000DM010-2EP1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 4096MB 12,1GB 8000MB primary ext4
