I managed to download an OpenVPN file from VPN Gate, imported it and connected it. The VPN was connected and my IP was changed, but I couldn't access certain page (which I believe is blocked by my ISP) as it would like when using my local wireless network. As far as I know a VPN should bypass any blocks by my ISP.
I tried, using DNS and direct IP address (also using both TCP and UDP method), but none of them works. I also tried connecting with both wireless and USB wired from my Android phone but none works, too. (wireless is tethered from Android phone)
Though, with same VPN configuration, I can reach the page with my phone.
I'm connected from a phone with LTE connection, and it's my only source of internet until this post edited.
Here is the output of ifconfig, route and traceroute google.com in order. I typed it when connected to VPN.
Output of ip route show (while connected to VPN) and resolv.conf file:
$ ip route show
default via 10.211.1.98 dev tun0  proto static  metric 50
default via 192.168.43.1 dev wlo1  proto static  metric 600
10.211.1.98 dev tun0  proto kernel  scope link  src 10.211.1.97  metric 50
131.147.175.48 via 192.168.43.1 dev wlo1  proto static  metric 600
169.254.0.0/16 dev wlo1  scope link  metric 1000
192.168.43.0/24 dev wlo1  proto kernel  scope link  src 192.168.43.77  metric 600
$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
How do I reach the blocked page, then?
Aryo Adhi
  • 1,397
  • 15
  • 41
A quick workaround suggested by Mukesh (referring to this question) is the current acceptable solution for me.
By changing IPv4 DNS servers on my local network (let it be, 8.8.8.8 and 8.8.4.4), it went through the blocked page (i.e Reddit) without any problem.
This is probably one of numerous applicable answers for me.
Aryo Adhi
  • 1,397
  • 15
  • 41
The problem is really that the nameservers is not updated. They still point to your ISP's NS, and DNS is the common way of doing blocking.
Usually the VPN provider will push out a DNS server when connecting. To actually use these, you have to ask OpenVPN to change the system settings. Add the following lines to your OpenVPN config file:
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-conf
This is a script that will update your resolv.conf automatically when connecting, and again when disconnecting.
The good news with DNS blocking is that you may not need a VPN. Try simply specifying different DNS servers, without connecting to a VPN, and see if that allows you to access blocked sites.
vidarlo
  • 23,497
