After downloading and extracting them, how do I install the CMAKE binary files in Ubuntu 14.04 so that they're recognized with cmake --version?
Zanna
  • 72,312
Anthony
You have to put your downloaded cmake on your $PATH, either is $HOME/bin or /usr/local/bin (or /opt and add /opt to your path) and then in setting a path put the location of your downloaded cmake first
For example,
PATH=$HOME/bin:$PATH
or
PATH=/usr/local/bin:$PATH
would search and find your downloaded cmake first if it were in $HOME/bin or /usr/local/bin respectively.
If you used PATH=$PATH:$HOME/bin is would use the system cmake first (due to order of directories in $PATH )
Alternately you can use to full path to your cmake, for example
/home/your_user/Downloads/cmake --version
or
$HOME/bin/cmake --version
Panther
  • 104,528
