I tried installing wine using the command
 sudo apt-get install wine
but I got the following
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
I don't understand. Any help?
Zanna
  • 72,312
This simply means that some other command running somewhere else on the system is running dpkg (your bottom line package installer). Check all terminal tabs / software center / software updater stuff to see if you have any commands that have not terminated, such as:
apt upgrade
apt install xyz
apt -f install
dpkg xyz
As mentioned by user535733, turning off your computer is probably not the best idea, since if something is running in the background, shutting down the computer could result in dependency issues which prevent the computer from starting.
Other ideas for finding running dpkg or apt commands include looking in top / htop, or simply running
ps -e | grep dpkg
ps -e | grep apt
anonymous2
  • 4,325
