The kind of transparency I'm seeing in Ubuntu 11.10 is it will show the desktop wallpaper. This is not what I want.
When I first installed Ultimate Edition, transparent windows would show the window right below them, not the desktop. This is the kind of transparency that I want. How can I get Ubuntu to function like this again?
Caesium
  • 16,207
  • 42
  • 48
z-buffer
  • 333
I'm not entirely sure what of this accomplished what you're trying to do, but here's what I did that did result in the transparency you want:
  1. Installed Ubuntu 11.10
  2. Installed Xfce4
  3. Turned on 'Enable display compositing' (Settings -> Settings Manager -> Window Manager Tweaks -> Compositor (tab).
But, before I turned on compositing, I wasn't getting pseudo-transparency, either (which is what you're describing). If you're early enough in the set up process, it might be worth installing Ubuntu 11.10 fresh, and adding Xfce4 manually. I've had much better results doing it that way in the past. (for both 10.04 and 11.10)
David Oneill
  • 12,614
With recent XFCE I was able to scroll-to-fade combining with the ALT key and scrolling on the title bar, but only when desktop zoom is disabled in the compositor section of window manager tweaks.
icarito
  • 101
Ultimate Edition uses to come pre-installed with compiz and its plugins.
You need to install Compiz and check if the default plugins includes those needed to enable transparent windows, such as "Opacity, Brightness and Saturation", which controls the transparency of the windows, "Opacify" reduces/increases the opacity of the window based on the mouse over windows behavior.
See this https://askubuntu.com/a/1046/9598. And this: https://askubuntu.com/search?q=transparent&submit=search (a search in the site will provide lots of answers to your question).
I hope this give you a clue on where to begin.
BTW: I am not sure that Compiz will work fine on XFCE, when I tried Ultimate Edition it didn't, but it was the 2.8 release which used Gnome as Desktop Manager.
Good luck!
-2
After you have done what Geppettvs D'Constanzo said, you can hold down alt over the window you want to make transparent, then scroll. It works wonderfully and you can see any non-minimized windows beneath. I hope it will work for you in XFCE!
