Possible Duplicate:
Why can't Ubuntu see any free space?
I have a hard drive that should have close to 40GB free. However, when I just restarted the computer, Ubuntu popped up with the notification stating that the drive has 0 bytes of space remaining.
When I run df -h I get the following output:
Filesystem            Size  Used Avail Use% Mounted on
/dev/sdc5             721G  684G     0 100% /media/Storage1
As you can tell, 684G + 0GB != 721GB, instead I should have 37GB available.
Running fsck /dev/sdc5 showed that there are no problems and nothing was recovered on the ext3 mount.
Where did my missing 30GB go? How can I get them back?
Gus E
  • 1,796
Sounds like the 5% reservation for the root user. You can change that with
sudo tune2fs -m 1 /dev/sdc5
to 1% like in this example. If it is just a storage partition 0% should be OK too.
By default 5% on a ext3 file system are reserved for root. You can change this using
sudo tune2fs -m 0 /dev/sdc5
