I'm looking for a solution to preview images or videos of a folder in it's icon to identify easily. This feature has been present in Windows ever since but for some reason, I am unable to find it in Linux desktop environments. I have Xubuntu 16.04. If you can help then it will be great. I'm attaching a sample image for proper understanding.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
The answer by Anderson doesn't really fit to the question. File previews weren't asked and are indeed part of Nautilus (haven't used the other ones, so can only tell about Nautilus).
To get folder previews/thumbnails with Nautilus you may try Cover Thumbnailer.
It's working for me good with Music and Pictures folders and pretty unreliable with "Other" folders, but with its settings gui, you're free to add more folders to the first ones and so bypass last one.
Be aware that Cover Thumbnailer is not part of the official repositories. Using its ppa is the easiest way to install it.
Image previews are available in:
  • Dolphin (KDE DE), select View->View Mode->Icons;
  • Nautilus (GNOME DE), select the grid of dots in the upper right (View Items as Grid of Icons);
  • Caja (MATE DE), select Edit->Preferences->Preview, Other Previewable Files, Show thumbnails to Always (also you can set Only for files smaller than to size needed).
  • Thunar (Xfce DE), select View->View as Icons.
N0rbert
  • 103,263
