Have been running a test instance of a NAS using a ZFS as mentioned in Restoring an Ubuntu Server using ZFS RAIDZ for data.
This week one of my disks died. Shouldn't be a problem, should it (the benefits of RAID being resilience as well as performance)?
Except that my ZFS pool got corrupted, as in:
andy@ubuntu:~$ sudo zpool status -v
  pool: tank
 state: UNAVAIL
status: One or more devices could not be used because the label is missing
        or invalid.  There are insufficient replicas for the pool to continue
        functioning.
action: Destroy and re-create the pool from
        a backup source.
   see: http://www.sun.com/msg/ZFS-8000-5E
  scan: none requested
config:
    NAME        STATE     READ WRITE CKSUM
    tank        UNAVAIL      0     0     0  insufficient replicas
      raidz1-0  UNAVAIL      0     0     0  insufficient replicas
        sdb     FAULTED      0     0     0  corrupted data
        sdc     FAULTED      0     0     0  corrupted data
        sdd     UNAVAIL      0     0     0
Fortunately this is a test instance and so I can easily start again. But what if this pool contained important data? What would the right next step(s) be to recover the data and restore my NAS to working order? Or does ZFS automatically try all possible restoration approaches, such that the data is now toast?
Armed with the insight of @slashdot, I have mostly fixed my problem, but I don't really know what I did. Please examine the following trail and enlighten me.
In particular which of the following hypotheses are true and or what am I missing?
  1. Neither zdb -u tank nor zdb -dcsv tank did anything useful.
  2. The second zpool import -f tank worked when the first one didn't because enough time had elapsed since the zpool export tank for ZFS to have a chance to fix itself.
  3. This whole episode had something to do with labels changing themselves after one of the drives failed (think it was sdb which caused sdc>sdb & sdd>sdb).
LOG
andy@ubuntu:~$ zpool status
  pool: tank
 state: UNAVAIL
        functioning.
        a backup source.
config:
            sdd     UNAVAIL      0     0     0
andy@ubuntu:~$ sudo zdb -u tank
zdb: can't open 'tank': No such device or address
andy@ubuntu:~$ sudo zpool scrub tank
cannot scrub 'tank': pool is currently unavailable
andy@ubuntu:~$ sudo zdb -bcsv tank
andy@ubuntu:~$ sudo zpool export tank
andy@ubuntu:~$ sudo zpool import tank
cannot import 'tank': pool may be in use from other system
use '-f' to import anyway
andy@ubuntu:~$ sudo zpool import -f tank
cannot import 'tank': one or more devices is currently unavailable
no pools available
andy@ubuntu:~$ sudo zpool status -x
no pools available
  pool: tank
 state: UNAVAIL
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
config:
        tank        UNAVAIL  insufficient replicas
          raidz1-0  UNAVAIL  insufficient replicas
            sdb     FAULTED  corrupted data
            sdb     UNAVAIL
            sdc     ONLINE
      pool: tank
 state: DEGRADED
status: One or more devices could not be used because the label is missing or
        invalid.  Sufficient replicas exist for the pool to continue
        functioning in a degraded state.
action: Replace the device using 'zpool replace'.
   see: http://www.sun.com/msg/ZFS-8000-4J
  scan: scrub repaired 0 in 0h13m with 0 errors on Mon Nov 21 09:22:11 2011
config:
        tank                      DEGRADED     0     0     0
          raidz1-0                DEGRADED     0     0     0
            10820373921989571629  UNAVAIL      0     0     0  was /dev/sdb1
            sdb                   ONLINE       0     0     0
            sdc                   ONLINE       0     0     0
errors: No known data errors
andy@ubuntu:~$
I think the previous posters have highlighted the problem. The probable cause was due to the way you specified the disks.
My experience is with ZFS on Ubuntu. Though I do use ZFS on freenas as well, I've never had to delve into the bsd implementation.
Certainly for Ubuntu, you are strongly advised to specify your devices by-id rather than by descriptor: i.e. /dev/disk/by-id/scsi-SATA-long string that uniquely ids the physical disk rather than /dev/sda.
Using by-id device removes any dependence on the specific SATA port the disk is connected to.
Gareth
Gareth
  • 173
Can you just mixed up disks?
Once I mixed up disks and zpool said "disks contain corrupted data". After I connected disks in previous sequence it started working.
Maybe after you imported tank zpool recognized right sequence.
BBK
  • 2,119
It looks like your pool may not actually be corrupted. Though from the output it seems like multiple devices may be in trouble. I am guessing multiple disks may be in questionable state, hence the faulted state on sdb and sdc. Figure out what might be wrong with them and your pool may prove you wrong. This does not look like a fatal state of pool.
slashdot
  • 234
