I have done a terrible deed while linking javac to /usr/bin
I accidentally pasted wrong command line and now I cannot use sudo anymore and thus, I can't access any file or folder which needs permission.
It says
bash: /usr/bin/sudo: Too many levels of symbolic links
The command line which I wrongly paseted is
sudo ln -f -s sudo ln -f -s /opt/jdk1.8.0_151/bin/javac /usr/bin
But it should be
But I already messed up. So, please, if anyone have any idea of how I can fix that, I'll be very thankful.
Run the following to fix the error.
/usr/bin/sudo rm /usr/bin/javac
If the above line doesn't work, see if you can change to the root user then try again:
su root
rm /usr/bin/javac
Then rerun the correct line.
Hope this helps!
Terrance
  • 43,712
