I changed my laptop Hard disk to SSD and then I found a box to convert the HDD to USB. And when I plug it to my notebook it doesn't show. Please help me.
mehman@HP:~$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 931,5G  0 disk
├─sda1   8:1    0     1K  0 part
├─sda3   8:3    0 687,4G  0 part
├─sda5   8:5    0  19,1G  0 part [SWAP]
└─sda6   8:6    0 225,1G  0 part /
sr0     11:0    1  1024M  0 rom
mehman@HP:~$ dmesg | tail
[  308.959810] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[  314.335813] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[  314.543822] usb 3-1: device not accepting address 6, error -62
[  314.543873] usb usb3-port1: unable to enumerate USB device
[ 1830.932266] usb 3-1: new high-speed USB device number 7 using xhci_hcd
[ 1831.052285] usb 3-1: device descriptor read/64, error -71
[ 1831.280280] usb 3-1: device descriptor read/64, error -71
[ 1831.509791] usb 3-1: new high-speed USB device number 8 using xhci_hcd
[ 1831.628330] usb 3-1: device descriptor read/64, error -71
[ 1831.856278] usb 3-1: device descriptor read/64, error -71
mehman@HP:~$
Case looks like this . Case has USB 3.0 Micro-B 10 pin and other side is USB 2.0 Type A output.
but HDD is Samsung hm641ji 640 GB
I tested it on 3 laptops with usb and a PC. It only works when I connect it inside the laptop or PC.
Samsung hm641ji says DC +5V 0.85A Maybe USB-B is not enough?
With your disk taking 850ma, and the case taking something, you are at or over the limit of USB3 power supply (900 ma). I'd use an external USB 5v power supply on the case (the round hole), to supply the necessary power. Possibly a Y USB connector (two USB3 A male to the micro B) would enable the necessary power to be drawn off two USB 3 ports on the computer, but that may depend upon how things are wired up inside the computer.
ubfan1
  • 19,049
