I have installed virtual box 5.2
dpkg -l |grep virtualbox
virtualbox-5.2 5.2.4-119785~Ubuntu~xenial amd64 Oracle VM VirtualBox
I'm using UBUNTU 16.04
But when I boot in secure mode I can't start vboxdrv service I got the following errors after trying to start the service manually:
service vboxdrv start
Job for vboxdrv.service failed because the control process exited with error code. See "systemctl status vboxdrv.service" and "journalctl -xe" for details.
And the results of journalctl -xe are:
ene 03 16:36:43 nb-efsandino vboxdrv.sh[3190]: Building VirtualBox kernel modules.
ene 03 16:36:59 nb-efsandino vboxdrv.sh[7461]: VirtualBox kernel modules built.
ene 03 16:36:59 nb-efsandino vboxdrv.sh[3179]: vboxdrv.sh: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
ene 03 16:36:59 nb-efsandino vboxdrv.sh[7463]: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
ene 03 16:36:59 nb-efsandino systemd[1]: vboxdrv.service: Control process exited, code=exited status=1
ene 03 16:36:59 nb-efsandino systemd[1]: Failed to start VirtualBox Linux kernel module.
-- Subject: Unit vboxdrv.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit vboxdrv.service has failed.
-- The result is failed.
ene 03 16:36:59 nb-efsandino systemd[1]: vboxdrv.service: Unit entered failed state.
ene 03 16:36:59 nb-efsandino systemd[1]: vboxdrv.service: Failed with result 'exit-code'.
ene 03 16:36:59 nb-efsandino polkitd(authority=local)[1118]: Unregistered Authentication Agent for unix-process:3142:3022871 (system bus name :1.1643, object path /org/freedesktop/PolicyKit1/Authenticatio
ene 03 16:36:59 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: the GVariant format string '(u)' has a type of '(u)' but the given value has a type of '()'
ene 03 16:36:59 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: g_variant_get: assertion 'valid_format_string (format_string, TRUE, value)' failed
ene 03 16:37:09 nb-efsandino sshd[7466]: Accepted publickey for efsandino from 199.14.10.195 port 50277 ssh2: RSA SHA256:O0FAZNK66J7onAXe1zmqc8ac5uxNHGVbU0ykIoYdvCI
ene 03 16:37:09 nb-efsandino sshd[7466]: pam_unix(sshd:session): session opened for user efsandino by (uid=0)
ene 03 16:37:09 nb-efsandino systemd-logind[925]: New session 563 of user efsandino.
-- Subject: A new session 563 has been created for user efsandino
-- Documentation: http://www.freedesktop.org/wiki/Software/systemd/multiseat
-- A new session with the ID 563 has been created for the user efsandino.
-- The leading process of the session is 7466.
ene 03 16:37:09 nb-efsandino systemd[1]: Started Session 563 of user efsandino.
-- Subject: Unit session-563.scope has finished start-up
-- Unit session-563.scope has finished starting up.
-- The start-up result is done.
ene 03 16:37:09 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: the GVariant format string '(u)' has a type of '(u)' but the given value has a type of '()'
ene 03 16:37:09 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: g_variant_get: assertion 'valid_format_string (format_string, TRUE, value)' failed
ene 03 16:37:10 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: the GVariant format string '(u)' has a type of '(u)' but the given value has a type of '()'
ene 03 16:37:10 nb-efsandino gnome-session[9367]: (vino-server:9541): GLib-CRITICAL **: g_variant_get: assertion 'valid_format_string (format_string, TRUE, value)' failed
ene 03 16:37:10 nb-efsandino sshd[7492]: Received disconnect from 199.14.10.195 port 50277:11: disconnected by user
ene 03 16:37:10 nb-efsandino sshd[7492]: Disconnected from 199.14.10.195 port 50277
ene 03 16:37:10 nb-efsandino sshd[7466]: pam_unix(sshd:session): session closed for user efsandino
ene 03 16:37:10 nb-efsandino systemd-logind[925]: Removed session 563.
-- Subject: Session 563 has been terminated
-- A session with the ID 563 has been terminated.
Any Advice, How to solve this issue ? Thanks in Advance !
