I need to upgrade my very old SUSE Linux and I want to switch from SUSE to Ubuntu.
I was in the process of finding out how to create a bootable USB stick, when I realized that the oldest and smallest of my spare sticks has an .exe (wubi) which, if its readme is true, would allow me to install Ubuntu starting from a Windows machine.
Now I wonder if such installers exist that run on Linux too. This would be far easier than burning an ISO image, taking the risk that the target box can't boot from USB, etc.
Edit 1:
Meanwhile I found a small ISO image for Ubuntu 7 (yes, 7, not 17, no typo) that fits on my 1GB stick. I managed to burn it on the stick, using my other computer (System->Administration->USB startup disc creation) and succeeded to start the box, using this image.
It leads me to some kind of shell that has BusyBox v1.1.3 with (initramfs) as prompt. I can do pwd and even apt-get, but apt-get tells me that libapt-pkg-libc6.6-... is missing. I don't think this is supposed to happen.
The next part of the adventure is that I'm downloading an iso image of ubuntu16.04.3 (1.5GB), find the next bigger stick and try it again.
Edit 2:
Now I have downloaded what I hope is an up-to-date iso-image, cksum gives me
1089871577 1587609600 ubuntu-16.04.3-desktop-amd64.iso
After some skirmishing with the old Acer BIOS, the box tries to boot from the USB, but gives Warnings:
Missing parameter in configuration file.
Unknown keyword in configuration file.
Upon that, I see what looks like a prompt boot: that reacts to nothing but a hard reset via the power switch, except that after what seems about half an hour, the box loses patience and boots anew, with the same result.
Edit 3:
The ISO image of Ubuntu 16 can now be booted. The trick was simply to type "help" into the prompt and wait for things to happen.
One last problem remains: it only boots Ubuntu, but does not install it. What is missing?
karel
  • 122,292
  • 133
  • 301
  • 332
debootstrap
Bootstrap a basic Debian system
debootstrap is used to create a Debian base system from scratch, without requiring the availability of dpkg or apt. It does this by downloading .deb files from a mirror site, and carefully unpacking them into a directory which can eventually be chrooted into.
debootstrap is not far easier than creating a bootable Ubuntu live USB or burning an Ubuntu ISO image. It is not even easier than booting from the Ubuntu Minimal CD which is a lightweight, text-only Ubuntu installer that can boot on many computers which can't boot the full-sized Ubuntu installer media. The Ubuntu Minimal CD allows you to install package groups which is very convenient, and you can also install the same package groups without using the Ubuntu Minimal CD by installing the tasksel package.
How to install Linux using debootstrap
Install debootstrap
If you are installing from a non-Debian based distribution, your distribution may or may not have debootstrap available. To get debootstrap, you can download it directly from a Debian mirror.
To view the packages available, use a web browser, or use this command:
wget --no-remove-listing -O /tmp/deboot.html -q http://ftp.us.debian.org/debian/pool/main/d/debootstrap && grep 'all.deb' /tmp/deboot.html | awk -F 'href' '{print $2}' | cut -d '"' -f2
The latest version of debootstrap is debootstrap_1.0.123_all.deb
wget -P /tmp/debootstrap http://ftp.us.debian.org/debian/pool/main/d/debootstrap/debootstrap_1.0.123_all.deb
Unpacking the .deb file
cd /tmp/debootstrap
ar vx debootstrap_1.0.123_all.deb
tar -xf data.tar.gz
Temporary setup
sudo ln -s /tmp/debootstrap/usr/sbin/debootstrap /usr/sbin/debootstrap
sudo ln -s /tmp/debootstrap/usr/share/debootstrap /usr/share/debootstrap
Setup the target partition for install
Create your filesystem, your mount point, and mount your partition:
sudo mkfs.ext4 -L Debian /dev/sda1
sudo mkdir /mnt/deboot
sudo mount -t ext4 /dev/sda1 /mnt/deboot
Installing the base system with network access
sudo debootstrap --arch amd64 focal /mnt/deboot http://archive.ubuntu.com/ubuntu
Preparing the chroot environment
Copy the mounted file systems table. It keeps the df command happy. (It will be overwritten upon boot.)
sudo cp /etc/mtab /mnt/deboot/etc/mtab
Binding the virtual filesystems. Until your new install is booting on it's own, we'll borrow these from the host.
sudo mount -o bind /dev /mnt/deboot/dev
sudo mount -o bind /proc /mnt/deboot/proc
sudo mount -o bind /sys /mnt/deboot/sys
Continuing the installation within chroot
Entering the chroot environment:
sudo chroot /mnt/deboot /bin/bash
Since we used the --include option to get grub, it was installed, but not configured.
sudo grub-install /dev/sda
sudo update-grub
Setting up /etc/fstab for the root filesystem. Use the blkid command to get the UUID of /dev/sda1.
sudo blkid /dev/sda1
Then add this entry to /etc/fstab using the UUID output from the command above:
sudo UUID=79168060-9d9c-4cf6-8ee9-bb846aee589b / ext4 defaults,errors=remount-ro 0 1
Give your new install a name. If not, your new install won't have a name, or inherit the name of the host you are installing from.
sudo echo "<name-your-host>" > /etc/hostname
Configure your locale.
sudo dpkg-reconfigure locales
Create a password for root.
sudo chroot# passwd
Create a normal user.
sudo adduser <your-user-name>
Setting up the network (eth0)
Some basic tools are already included to manage your network, but nothing is configured for you yet. If you plan on installing a desktop environment, that may bring in tools such as network-manager or wicd to automatically configure your network.
You can bring up your network manually each boot with the tools dhclient or ifconfig.
For a dynamic IP (DHCP):
sudo dhclient -v eth0
For a static IP:
sudo ifconfig -v eth0 192.0.2.7 netmask 255.255.255.0 up
You can have this automatically done for you when the system boots by editing the file below.
For DHCP, the /etc/network/interfaces file should look like this:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo iface lo inet loopback
The primary network interface
allow-hotplug eth0 iface eth0 inet dhcp
For a static IP, the /etc/network/interfaces file should look like this:
auto eth0 iface eth0 inet static address 192.0.2.7 netmask 255.255.255.0 gateway 192.0.2.254
Install a display manager and a window manager
Unless you're using this for a headless server, might be nice to have some sort of desktop to play with. Don't forget to update the package manager if you wish to install new packages:
sudo apt-get update
Here are some examples of installing a desktop:
sudo apt install xserver-xorg wdm fluxbox xterm # -or -
sudo apt install xserver-xorg lightdm xfce4 # -or -
sudo apt install gdm3 gnome # -or -
sudo apt install kdm kde-standard
You can use also use tasksel to install a desktop for you. To see the available options:
sudo tasksel --new-install
Finishing the install
Clean the package cache:
sudo apt-get clean
Update the ramdisk:
sudo update-initramfs -u -k all
Exit the chroot environment:
sudo exit
Source: How to install to install Linux using debootstrap
karel
  • 122,292
  • 133
  • 301
  • 332
