In this post I look rather for clarification than technical solution (the problem is already solved, see below).
I just upgraded from 14.04 to 16.04 and installed a fresh Firefox, which happened to be Quantum 57.0.3 (64 bit). Flash didn't work, thus I installed flashplugin-installer, which has in its description:
The Adobe Flash Player plugin will work with a range of web-browsers >including, limited to: * Firefox
Unfortunately it didn't help. What helped was the installation of browser-plugin-freshplayer-pepperflash instead. The description of the latter package states:
The main goal of the project is to get PPAPI (Chrome) plugins working in Firefox (and any other web-browser supporting NPAPI plugins
I wanted to understand why the former package didn't work, thus I started to read and found out here that Firefox since ver 52 does not support NPAPI plugins, except for Adobe Flash. Therefore, it seemed that having adobe-flashplugin installed should be enough and one does not need to deal with the NPAPI/PPAPI issues. Indeed, after I removed browser-plugin-freshplayer-pepperflash and sticked to adobe-flashplugin, everything worked fine. Thus, I suspect that the crux was in one of the packages required by browser-plugin-freshplayer-pepperflash, not that package itself.
Would the conclusion be that Firefox in 16.04 ships without Flash support, even when adobe-flashplugin is present (I wonder why)? If so, some users might bump at this problem, just as I did.
Maciek
  • 141
I cannot make sense of your observations that adobe-flashplugin works without browser-plugin-freshplayer-pepperflash but flashplugin-installer does not. adobe-flashplugin and flashplugin-installer provide the very same NPAPI plugin. Maybe you simply forgot to restart your browser or something...
This page provides a concise summary on the topic, including an attempt to explain when browser-plugin-freshplayer-pepperflash may be a useful.
