My Acer Aspire E5 575G has a Qualcomm Atheros QCA9377. I have tried reinstalling my kernel, I have reinstalled drivers(ath10k), installing backport, have turned off powersaving, have installed wicd, etc... only thing that has slightly helped is disabling WMM in the router settings. My kernel version is 4.10.0-42-generic. Typical speeds right next to the router are 15 mbps up and down. I have a 50/50 plan. 50+ mbps is my ethernet speed. when bluetooth is on, my mbps is half of the current slow wifi. Here are some of the commands y'all often ask for:
tcr-g@TCR:~/backports-20151120$ lshw -C network
WARNING: you should run this program as super-user.
*-network
description: Wireless interface
product: Qualcomm Atheros
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 31
serial: 3c:a0:67:b7:f9:b5
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath10k_pci driverversion=4.10.0-42-generic firmware=WLAN.TF.1.0-00267-1 ip=192.168.1.13 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:132 memory:b4000000-b41fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0.1
bus info: pci@0000:04:00.1
logical name: enp4s0f1
version: 12
serial: a8:1e:84:8c:f3:95
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8411-2_0.0.1 07/08/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:129 ioport:3000(size=256) memory:b4204000-b4204fff memory:b4200000-b4203fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
tcr-g@TCR:~/backports-20151120$ dmesg | grep ath
[ 2.605692] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 3.753058] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:03:00.0.bin failed with error -2
[ 3.753072] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[ 3.756304] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
[ 3.756307] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 3.756709] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.1.0-00267-1 api 5 features ignore-otp crc32 79cea2c7
[ 3.826673] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 93da0176
[ 5.624886] ath10k_pci 0000:03:00.0: htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 5.631635] ath: EEPROM regdomain: 0x69
[ 5.631636] ath: EEPROM indicates we should expect a direct regpair map
[ 5.631637] ath: Country alpha2 being used: 00
[ 5.631638] ath: Regpair used: 0x69
[ 5.635286] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[ 8.219280] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[ 17.699227] ath10k_pci 0000:03:00.0 wlp3s0: disabling HT as WMM/QoS is not supported by the AP
[ 17.699229] ath10k_pci 0000:03:00.0 wlp3s0: disabling VHT as WMM/QoS is not supported by the AP
[ 17.706891] ath: EEPROM regdomain: 0x8348
[ 17.706892] ath: EEPROM indicates we should expect a country code
[ 17.706892] ath: doing EEPROM country->regdmn map search
[ 17.706893] ath: country maps to regdmn code: 0x3a
[ 17.706893] ath: Country alpha2 being used: US
[ 17.706894] ath: Regpair used: 0x3a
[ 17.706894] ath: regdomain 0x8348 dynamically updated by country IE
[21149.836191] ath10k_pci 0000:03:00.0: failed to install key for vdev 0 peer 00:7f:28:79:03:4e: -110
[21176.174975] ath10k_pci 0000:03:00.0 wlp3s0: disabling HT as WMM/QoS is not supported by the AP
[21176.174976] ath10k_pci 0000:03:00.0 wlp3s0: disabling VHT as WMM/QoS is not supported by the AP
[21176.187707] ath: EEPROM regdomain: 0x8348
[21176.187708] ath: EEPROM indicates we should expect a country code
[21176.187709] ath: doing EEPROM country->regdmn map search
[21176.187710] ath: country maps to regdmn code: 0x3a
[21176.187711] ath: Country alpha2 being used: US
[21176.187711] ath: Regpair used: 0x3a
[21176.187712] ath: regdomain 0x8348 dynamically updated by country IE
[22095.165638] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.267894] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.370380] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.472716] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.575322] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.677724] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.780064] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.882586] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22095.984765] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22096.087341] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[22106.315653] ath10k_warn: 10 callbacks suppressed
[22106.315691] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[24125.507965] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[25301.490471] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[25964.493815] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[28246.217197] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[28573.272844] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[28575.380226] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[28887.948033] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[30208.862759] __mutex_lock_slowpath+0x193/0x290
[30208.862822] path_openat+0x2ac/0x1430
[30208.862883] entry_SYSCALL_64_fastpath+0x1e/0xad
[30564.955587] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[30565.470017] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[30899.273952] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[30899.274179] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[30903.578321] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[31557.410765] ath10k_pci 0000:03:00.0: no channel configured; ignoring frame(s)!
[34913.254867] ath10k_pci 0000:03:00.0 wlp3s0: disabling HT as WMM/QoS is not supported by the AP
[34913.254871] ath10k_pci 0000:03:00.0 wlp3s0: disabling VHT as WMM/QoS is not supported by the AP
[34913.270099] ath: EEPROM regdomain: 0x8348
[34913.270100] ath: EEPROM indicates we should expect a country code
[34913.270101] ath: doing EEPROM country->regdmn map search
[34913.270102] ath: country maps to regdmn code: 0x3a
[34913.270103] ath: Country alpha2 being used: US
[34913.270103] ath: Regpair used: 0x3a
[34913.270105] ath: regdomain 0x8348 dynamically updated by country IE
[35173.320845] ath10k_pci 0000:03:00.0 wlp3s0: disabling HT as WMM/QoS is not supported by the AP
[35173.320849] ath10k_pci 0000:03:00.0 wlp3s0: disabling VHT as WMM/QoS is not supported by the AP
[35173.336678] ath: EEPROM regdomain: 0x8348
[35173.336678] ath: EEPROM indicates we should expect a country code
[35173.336679] ath: doing EEPROM country->regdmn map search
[35173.336680] ath: country maps to regdmn code: 0x3a
[35173.336681] ath: Country alpha2 being used: US
[35173.336682] ath: Regpair used: 0x3a
[35173.336683] ath: regdomain 0x8348 dynamically updated by country IE
[39817.251694] ath10k_pci 0000:03:00.0: failed to install key for vdev 0 peer 00:7f:28:79:03:4e: -110
[39817.375135] ath10k_pci 0000:03:00.0 wlp3s0: disabling HT as WMM/QoS is not supported by the AP
[39817.375138] ath10k_pci 0000:03:00.0 wlp3s0: disabling VHT as WMM/QoS is not supported by the AP
[39817.384885] ath: EEPROM regdomain: 0x8348
[39817.384886] ath: EEPROM indicates we should expect a country code
[39817.384887] ath: doing EEPROM country->regdmn map search
[39817.384888] ath: country maps to regdmn code: 0x3a
[39817.384889] ath: Country alpha2 being used: US
[39817.384890] ath: Regpair used: 0x3a
[39817.384891] ath: regdomain 0x8348 dynamically updated by country IE
tcr-g@TCR:~/backports-20151120$ sudo iw reg get
[sudo] password for tcr-g:
country US: DFS-FCC
(2402 - 2472 @ 40), (N/A, 30), (N/A)
(5170 - 5250 @ 80), (N/A, 17), (N/A)
(5250 - 5330 @ 80), (N/A, 23), (0 ms), DFS
(5490 - 5730 @ 160), (N/A, 23), (0 ms), DFS
(5735 - 5835 @ 80), (N/A, 30), (N/A)
(57240 - 63720 @ 2160), (N/A, 40), (N/A)
tcr-g@TCR:~/backports-20151120$ modinfo ath10k_pci; dkms status
filename: /lib/modules/4.10.0-42-generic/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
firmware: ath10k/QCA9377/hw1.0/board.bin
firmware: ath10k/QCA9377/hw1.0/firmware-5.bin
firmware: ath10k/QCA6174/hw3.0/board-2.bin
firmware: ath10k/QCA6174/hw3.0/board.bin
firmware: ath10k/QCA6174/hw3.0/firmware-5.bin
firmware: ath10k/QCA6174/hw3.0/firmware-4.bin
firmware: ath10k/QCA6174/hw2.1/board-2.bin
firmware: ath10k/QCA6174/hw2.1/board.bin
firmware: ath10k/QCA6174/hw2.1/firmware-5.bin
firmware: ath10k/QCA6174/hw2.1/firmware-4.bin
firmware: ath10k/QCA9887/hw1.0/board-2.bin
firmware: ath10k/QCA9887/hw1.0/board.bin
firmware: ath10k/QCA9887/hw1.0/firmware-5.bin
firmware: ath10k/QCA988X/hw2.0/board-2.bin
firmware: ath10k/QCA988X/hw2.0/board.bin
firmware: ath10k/QCA988X/hw2.0/firmware-5.bin
firmware: ath10k/QCA988X/hw2.0/firmware-4.bin
firmware: ath10k/QCA988X/hw2.0/firmware-3.bin
firmware: ath10k/QCA988X/hw2.0/firmware-2.bin
license: Dual BSD/GPL
description: Driver support for Qualcomm Atheros 802.11ac WLAN PCIe/AHB devices
author: Qualcomm Atheros
srcversion: 55269025DC0881FB8B580CD
alias: pci:v0000168Cd00000050sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000042sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000046sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000056sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000040sv*sd*bc*sc*i*
alias: pci:v0000168Cd0000003Esv*sd*bc*sc*i*
alias: pci:v0000168Cd00000041sv*sd*bc*sc*i*
alias: pci:v0000168Cd0000003Csv*sd*bc*sc*i*
depends: ath10k_core
intree: Y
vermagic: 4.10.0-42-generic SMP mod_unload
parm: irq_mode:0: auto, 1: legacy, 2: msi (default: 0) (uint)
parm: reset_mode:0: auto, 1: warm only (default: 0) (uint)
bbswitch, 0.8, 4.10.0-42-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-43-generic, x86_64: installed
bbswitch, 0.8, 4.4.0-105-generic, x86_64: installed
nvidia-384, 384.90, 4.10.0-42-generic, x86_64: installed
nvidia-384, 384.90, 4.10.0-43-generic, x86_64: installed
nvidia-384, 384.90, 4.4.0-105-generic, x86_64: installed
tcr-g@TCR:~/backports-20151120$ sudo iwlist scan
vmnet1 Interface doesn't support scanning.
enp4s0f1 Interface doesn't support scanning.
vmnet8 Interface doesn't support scanning.
lo Interface doesn't support scanning.
wlp3s0 Scan completed :
Cell 01 - Address: XX:XX:XX:XX:XX:XX
Channel:8
Frequency:2.447 GHz (Channel 8)
Quality=57/70 Signal level=-53 dBm
Encryption key:on
ESSID:"delbhome"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=00000001bdbf8475
Extra: Last beacon: 48ms ago
IE: Unknown: 000864656C62686F6D65
IE: Unknown: 010882848B960C121824
IE: Unknown: 030108
IE: Unknown: 200100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: WPA Version 1
Group Cipher : CCMP
IE: Unknown: 2A0100
IE: Unknown: 32043048606C
IE: Unknown: 2D1A8C131B0000000000000000000000000000000000000000000000
IE: Unknown: 3D1608001B00000000000000000000000000000000000000
IE: Unknown: DD0900037F01010000FF7F
IE: Unknown: DD0A00037F04010000000000
IE: Unknown: 0706555320010B1B
tcr-g@TCR:~$ tracepath mtu
1?: [LOCALHOST] pmtu 1500
1: Wireless_Broadband_Router.home 1.350ms
1: Wireless_Broadband_Router.home 1.247ms
2: 47.187.192.1 10.938ms
3: 172.102.52.82 16.723ms
4: ae7---0.scr01.dlls.tx.frontiernet.net 14.487ms
5: ae1---0.cbr01.dlls.tx.frontiernet.net 12.700ms
6: no reply
7: no reply
8: 10ge3-15.core1.dal1.he.net 24.767ms
9: 100ge4-2.core1.phx2.he.net 49.334ms asymm 11
10: 100ge11-2.core1.lax2.he.net 64.731ms
11: xerocole-inc.gigabitethernet2-9.core1.lax2.he.net 40.325ms
12: no reply
13: no reply
14: no reply
15: no reply
16: no reply
17: no reply
18: no reply
19: no reply
20: no reply
21: no reply
22: no reply
23: no reply
24: no reply
25: no reply
26: no reply
27: no reply
28: no reply
29: no reply
30: no reply
Too many hops: pmtu 1500
Resume: pmtu 1500
tcr-g@TCR:~$
Thank you for your help!
