-1
i am running ubuntu gnome. when i attempt to do ANYTHING (update, upgrade, purge, remove, install...) with apt, i get
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 gnome-control-center : Depends: gnome-settings-daemon (>= 3.25.90) but 3.24.0-0ubuntu2 is to be installed
                        Recommends: gnome-online-accounts (>= 3.25.3) but 3.24.0-0ubuntu1 is to be installed
                        Recommends: rygel but it is not going to be installed or
                                    rygel-tracker but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
then when i use
sudo apt-get --fix-broken install
i get:
Preparing to unpack .../gnome-settings-daemon_3.26.2-1_amd64.deb ...
Unpacking gnome-settings-daemon (3.26.2-1) over (3.24.0-0ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives/gnome-settings-daemon_3.26.2-1_amd64.deb (--unpack):
 trying to overwrite '/lib/udev/rules.d/61-gnome-settings-daemon-rfkill.rules', which is also in package gnome-settings-daemon-schemas 3.24.0-0ubuntu2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Reinstalling /etc/xdg/autostart/org.gnome.SettingsDaemon.XRANDR.desktop that was moved away
Reinstalling /etc/xdg/autostart/org.gnome.SettingsDaemon.Orientation.desktop that was moved away
I cannot do anything unless i am using dpkg to install a local package. can anybody help?
waltinator
  • 37,856
i fixed it. it was a problem with my repositories -- i had added the kali repository for the tools, and it was trying to install kali's gnome over ubuntu's gnome. it is all good!
