Once i connect to a server using command Openssl s_client -quiet -connect ircs.overthewire. org:6697 What to do after I m connected It shows cursor on line in which I can type anything?
Asked
Active
Viewed 302 times
openssl s_client is basically the SSL version of netcat. You can use it to set up a SSL/TLS connection to a server, and then send the protocol data. As you're connecting to a IRC server by the looks of the command, you'd have to send IRC protocol Commands.
But this is probably not what you want. You probably want to use a IRC client to connect to the IRC server. Suggested IRC clients are hexchat, irssi, and many others.
