I'm under Ubuntu 14.04 and I tried to change Ubuntu logo Original logo
I replaced the ubuntu_logo.png with another custom .png file in
/lib/plymouth/themes/ubuntu-logo
but when it restarted, it shows this image instead of the custom .png file
Wrong output
N. Cornet
  • 442
  • 16
Vina L
  • 29
Once you're sure your new image is in the right format, then make sure your image (and any other configuration) is updated in the initial RAM disk.
The startup/shutdown system called Plymouth reads theme information straight from the regular disk filesystem on shutdown, so changing a PNG file is all you need to do for that. For startup, though, Plymouth runs before the real disk is available. Instead, it reads files from a special area called the "initial RAM disk".
To update the existing RAM disk with your new settings, run:
sudo update-initramfs -u
RJHunter
  • 161
