I have a new computer with a Seagate ST500DM002 SATA internal hard drive.
I am trying to install Ubuntu 11.10 64-bit on it but the installer does not recognize/detect/see the hard drive. When I reach the Installation type step, the panel which is supposed to show devices and partitions looks empty.
sudo fdisk -l shows only /dev/sda1, the USB drive from which I am running the installation. I have already tried the following two solutions without any success:
sudo apt-get remove dmraid- Switch the SATA mode in the BIOS from IDE to AHCI
I am sure it's not a hardware related problem as I have already successfully installed another operating system on the same computer.
The output of sudo lshw -class storage -class disk follows:
*-ide UNCLAIMED
description: IDE interface
product: ASMedia Technology Inc.
vendor: ASMedia Technology Inc.
physical id: 0
bus info: pci@0000:06:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: ide msi pm pciexpress cap_list
configuration: latency=0
resources: ioport:d040(size=8) ioport:d030(size=4) ioport:d020(size=8) ioport:d010(size=4) ioport:d000(size=16) memory:fe400000-fe4001ff
*-storage
description: SATA controller
product: 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
vendor: Intel Corporation
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi1
version: 05
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list emulated
configuration: driver=ahci latency=0
resources: irq:44 ioport:f0b0(size=8) ioport:f0a0(size=4) ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:fe705000-fe7057ff
*-cdrom
description: DVD-RAM writer
product: DVDRAM GH22NS70
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/scd0
logical name: /dev/sr0
version: EX00
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-scsi:0
physical id: 1
bus info: usb@1:1.2
logical name: scsi6
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sda
capabilities: partitioned partitioned:dos
configuration: signature=0004e5a4
*-scsi:1
physical id: 2
bus info: usb@1:1.3
logical name: scsi7
*-disk
product: Storage Device
vendor: USB Mass
physical id: 0.0.0
bus info: scsi@7:0.0.0
logical name: /dev/sdb
*-medium
physical id: 0
Any idea on what I could do to fix this problem?
