26
I have recently installed Ubuntu 16.04 on a Macbook Pro, everything works fine except the camera does not work/ is not found. Both Google Hangouts and the Cheese application say "no device found".
Anything I can install to get it working?
fosslinux
  • 3,881
As at 8/3/2020 follow the instructions Here. They come in two parts, make sure you also follow the ones for your platform. They are a bit jumbled on the site so I have included them below.
I'm running 18.04 LTS (Bionic) on a 2013 Macbook Pro. The instructions that worked for me were as follows:
sudo apt-get install git
sudo apt-get install curl xzcat cpio
git clone https://github.com/patjak/facetimehd-firmware.git
cd facetimehd-firmware
make
sudo make install
cd ..
sudo apt-get install kmod libssl-dev checkinstall
git clone https://github.com/patjak/bcwc_pcie.git
cd bcwc_pcie
make
sudo make install
sudo depmod
sudo modprobe -r bdc_pci
sudo modprobe facetimehd
sudo nano /etc/modules
**add line "facetimehd", write out (ctl+o) & close**
Most of those steps will need to be repeated every time the kernel is upgraded.
I also followed the instructions here prior to testing the colors of the camera.
theYnot
  • 733
  • 14
17
I followed the instructions here(under the section "webcam drivers") and it is working now.
cd bcwc_pcie/firmware
make
sudo make install
cd ..
make
sudo make install
sudo depmod
David Foerster
  • 36,890
  • 56
  • 97
  • 151
+1 for selected answer. Below is modified version for what worked as at Dec 11, 2021 here's what worked for me on Ubuntu 21.10
sudo apt-get install git curl cpio kmod libssl-dev checkinstall
make
sudo make install
cd ..
sudo depmod
Shekhar
  • 181
