Using phpinfo(), I have found that the installed version of PHP is 7.0.26. I want to upgrade it to PHP 7.2.
Samer Abu Gahgah
  • 281
  • 13
You have to install the PHP 7.2 (or any higher version 7.x) and remove your old version if you don't need it any more.
First add the PPA ppa:ondrej/php, run:
sudo add-apt-repository ppa:ondrej/php
sudo apt update
Second install the version you need 7.2 in your case, run:
sudo apt install php7.2
Third if you want to remove your old existing version, run
sudo apt remove php7.0
Samer Abu Gahgah
  • 281
  • 13
