I wanted to move the launcher to the bottom and have it aligned in the center, so I downloaded Plank. I didn't like it so I uninstalled it but the dock still appears when I move the cursor to the bottom of the screen.
Already tried to remove:
sudo apt-get remove plank
purged it
sudo apt-get purge plank
removed dependencies
sudo apt-get remove --auto-remove plank
removed all files from /usr/share/app-install/desktop and /var/cache/archives/, and the dock still shows. So how do I remove it totally?
Thanks
Uninstall plank
To remove just plank package itself from Ubuntu 16.04 (Xenial Xerus) execute on terminal:
Uninstall plank and it's dependent packages
To remove the plank package and any other dependant package which are no longer needed from Ubuntu Xenial.
Purging plank
If you also want to delete configuration and/or data files of plank from Ubuntu Xenial then this will work:
To delete configuration and/or data files of plank and it's dependencies from Ubuntu Xenial then execute:
sudo apt-get purge --auto-remove plank
Source: Here
eLi
  • 173
Try to reset its settings in dconf (installable with sudo apt-get install dconf-cli):
dconf reset -f /net/launchpad/plank/
Try to locate Plank in the current user XDG Autostart:
ls .config/autostart/
# then remove plank from here
rm .config/autostart/plank*.desktop
N0rbert
  • 103,263
