I am not able to install python-dev on my server. CPU - ARM64 OS - Ubuntu16.04.03
It failed due to unmet dependencies.
I have already tried for update,upgrade, force install and followed with multiple links to resolve. Looks issue specific to ARM64 with ubuntu16.04.3 ...
# sudo apt policy python-dev
python-dev:
  Installed: (none)
  Candidate: 2.7.11-1
  Version table:
     2.7.11-1 500
        500 http://us.ports.ubuntu.com/ubuntu-ports xenial/main arm64 Packages
I tried manually install dependent python pkg, but could not able to resolve dependency:
root@ubuntu:/home# sudo apt-get install python-dev
Reading package lists... Done
Building dependency tree
 python-dev : Depends: libpython-dev (= 2.7.11-1) but it is not going to be installed
              Depends: python2.7-dev (>= 2.7.11-1~) but it is not going to be installed
root@ubuntu:/home# sudo apt-get install python2.7-dev
 python2.7-dev : Depends: libpython2.7-dev (= 2.7.12-1ubuntu0~16.04.2) but it is not going to be installed
                 Depends: libpython2.7 (= 2.7.12-1ubuntu0~16.04.2) but it is not going to be installed
root@ubuntu:/home# sudo apt-get install libpython2.7
 libpython2.7 : Depends: libpython2.7-stdlib (= 2.7.12-1ubuntu0~16.04.1) but 2.7.12-1ubuntu0~16.04.2 is to be installed
root@ubuntu:/home# sudo apt-get install libpython2.7-stdlib
libpython2.7-stdlib is already the newest version (2.7.12-1ubuntu0~16.04.2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Plz let me know if need to share more info.
Thanks
muru
  • 207,228
khemendra
  • 31
Try running
 sudo apt-get install -f
I was facing similar problem which some other packages and it worked. I hope you have already ran this command.
pandafy
  • 326
