-1
I'm using Ubuntu 14.04 LTS amd64. I will install Pinguy Builder, but i found some errors
I tried to install
sudo dpkg -i pinguybuilder_3.3-7_all.deb
and this is the output
(Reading database ... 167103 files and directories currently installed.)
Preparing to unpack pinguybuilder_3.3-7_all.deb ...
Unpacking pinguybuilder (3.3-7) over (3.3-7) ...
dpkg: dependency problems prevent configuration of pinguybuilder:
 pinguybuilder depends on squashfs-tools; however:
  Package squashfs-tools is not installed.
 pinguybuilder depends on casper; however:
  Package casper is not installed.
 pinguybuilder depends on libdebian-installer4; however:
  Package libdebian-installer4 is not installed.
 pinguybuilder depends on ubiquity-frontend-debconf; however:
  Package ubiquity-frontend-debconf is not installed.
 pinguybuilder depends on user-setup; however:
  Package user-setup is not installed.
 pinguybuilder depends on discover1 | discover; however:
  Package discover1 is not installed.
  Package discover is not installed.
 pinguybuilder depends on aufs-tools | unionfs-fuse; however:
  Package aufs-tools is not installed.
  Package unionfs-fuse is not installed.
 pinguybuilder depends on dpkg-dev; however:
  Package dpkg-dev is not installed.
 pinguybuilder depends on gksu; however:
  Package gksu is not installed.
 pinguybuilder depends on python-glade2; however:
  P
dpkg: error processing package pinguybuilder (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
 pinguybuilder
i tried to update and install one of uninstalled package
apt-get update && apt-get install squashfs-tools
errors is constantly there
Err http://id.archive.ubuntu.com trusty InRelease
Err http://id.archive.ubuntu.com trusty-updates InRelease
Err http://id.archive.ubuntu.com trusty-backports InRelease
Err http://id.archive.ubuntu.com trusty Release.gpg
  Could not resolve 'id.archive.ubuntu.com'
Err http://id.archive.ubuntu.com trusty-updates Release.gpg
Err http://id.archive.ubuntu.com trusty-backports Release.gpg
Err http://security.ubuntu.com trusty-security InRelease
Err http://extras.ubuntu.com trusty InRelease
Err http://security.ubuntu.com trusty-security Release.gpg
  Could not resolve 'security.ubuntu.com'
Err http://extras.ubuntu.com trusty Release.gpg
  Could not resolve 'extras.ubuntu.com'
Reading package lists... Done
W: Failed to fetch http://id.archive.ubuntu.com/ubuntu/dists/trusty/InRelease
W: Failed to fetch http://id.archive.ubuntu.com/ubuntu/dists/trusty-backports/InRelease
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/trusty-security/InRelease
W: Failed to fetch http://extras.ubuntu.com/ubuntu/dists/trusty/InRelease
W: Failed to fetch http://id.archive.ubuntu.com/ubuntu/dists/trusty/Release.gpg  Could not resolve 'id.archive.ubuntu.com'
W: Failed to fetch http://id.archive.ubuntu.com/ubuntu/dists/trusty-updates/Release.gpg  Could not resolve 'id.archive.ubuntu.com'
W: Failed to fetch http://id.archive.ubuntu.com/ubuntu/dists/trusty-backports/Release.gpg  Could not resolve 'id.archive.ubuntu.com'
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/trusty-security/Release.gpg  Could not resolve 'security.ubuntu.com'
W: Failed to fetch http://extras.ubuntu.com/ubuntu/dists/trusty/Release.gpg  Could not resolve 'extras.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 pinguybuilder : Depends: casper but it is not going to be installed
                 Depends: libdebian-installer4 but it is not going to be installed
                 Depends: ubiquity-frontend-debconf but it is not going to be installed
                 Depends: user-setup but it is not going to be installed
                 Depends: discover1 but it is not installable or
                          discover but it is not going to be installed
                 Depends: aufs-tools but it is not going to be installed or
                          unionfs-fuse
                 Depends: dpkg-dev but it is not going to be installed
                 Depends: gksu but it is not going to be installed
                 Depends: python-glade2 but it is not going to be installed
                 Depends: python-vte but it is not going to be installed
                 Depends: plymouth-x11 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
what is occurring with those packages? why i can't install them? how can i install pinguy builder correctly?
Vina L
  • 29
dpkg does not know about the repositories, and so cannot install the dependiencies.
To install the program and its dependincies, use apt:
sudo apt install ./pinguybuilder_3.3-7_all.deb
Source
