I've been having problems with Ubuntu recently. Namely, every proprietary driver I installed caused the system to hang hopelessly and indefinitely after suspending or closing the lid on my Inspiron 15 7559. I have made the decision to remove Ubuntu and use only Windows 10, which until recently I had been dual-booting.
The first problem:
I deleted the ~400GB partition dedicated to Ubuntu and merged it with the C: drive, and I removed the GRUB bootloader. Windows boots normally but when I press 'F12' on startup, the 'ubuntu' option is still there. This option boots into Windows, but I still want it removed.
The second problem:
In my attempt to coax my graphics driver to function properly, I added
GRUB_CMDLINE_LINUX="acpi_backlight=native acpi_osi="
to the GRUB. And even though the system no longer boots through the GRUB menu, the backlight during boot up is extremely dim.
I have tried creating a Windows USB and running
bootrec.exe /fixmbr
Afterwards, I am told "The operation completed successfully," but in truth, this does absolutely nothing.
I think, you get the UEFI boot menu option with 'ubuntu' string. You have to go to the UEFI(BIOS) setting and look for 'Boot options' there you can delete the 'ubuntu' option.
