I am looking for a simple, clean, robust solution to concatenate mp3 files.
I am aware of mp3wrap, but its concatenation seems oriented for a different job: easily splitting afterwards. That means that some players don't read track length correctly.
We could use cat, but is seems risky, as it probably messes with the metadata.
One could use ffmpeg: https://askubuntu.com/a/504794 . This has two downsides: one, it is complex, and two, ffmpeg is no longer supported.
One could use sox, but, in my tests, it seems very slow. Perhaps it is re-encoding the whole thing, and would be suitable to small jobs (I am trying to concatenate a 7 hour audiobook)
The best answer so far seems to be to download an external utility: http://mulholland.xyz/dev/mp3cat/. Wondering if there is nothing in the repositories to replace that?
I am wondering if there is no simple utility, similar to mp3wrap, that concatenates mp3 files into a "correct" mp3, with "correct" length, available on the repositories.
(btw, I am aware of question Concatenating several .mp3 files into one .mp3, but wanted to ask specifically for a more clean solution. I hope this is not considered a straight up duplicate and, in any case, that we can leave this question open to find a better solution, if only to close it later and post the good solution to that original question.)
