I'm working on an Ubuntu 16.04 and I have a little bit old Nvidia 9600 GT graphics card. It's CUDA enabled (1.1 computation capability) though legacy. I'm trying to take advantage of it while using Keras and to do so I followed this guide to install CUDA and this one to install cuDNN. The driver for my graphics card is the 304.104 version and the last CUDA version that supports my graphics card is 6.5. After installation I verified it by typing in the console:
$ nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2014 NVIDIA Corporation
Built on Thu_Jul_17_21:41:27_CDT_2014
Cuda compilation tools, release 6.5, V6.5.12
$ nvidia-smi
Fri Dec 22 23:02:08 2017
| NVIDIA-SMI 340.104 Driver Version: 340.104 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce 9600 GT Off | 0000:01:00.0 N/A | N/A |
| 40% 46C P0 N/A / N/A | 77MiB / 1023MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
Also the compilation of the deviceQuery sample succedeed:
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce 9600 GT"
CUDA Driver Version / Runtime Version 6.5 / 6.5
CUDA Capability Major/Minor version number: 1.1
Total amount of global memory: 1024 MBytes (1073414144 bytes)
( 8) Multiprocessors, ( 8) CUDA Cores/MP: 64 CUDA Cores
GPU Clock rate: 1625 MHz (1.62 GHz)
Memory Clock rate: 400 Mhz
Memory Bus Width: 256-bit
Maximum Texture Dimension Size (x,y,z) 1D=(8192), 2D=(65536, 32768), 3D=(2048, 2048, 2048)
Maximum Layered 1D Texture Size, (num) layers 1D=(8192), 512 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(8192, 8192), 512 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per multiprocessor: 768
Maximum number of threads per block: 512
Max dimension size of a thread block (x,y,z): (512, 512, 64)
Max dimension size of a grid size (x,y,z): (65535, 65535, 1)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): No
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 6.5, CUDA Runtime Version = 6.5, NumDevs = 1, Device0 = GeForce 9600 GT
Result = PASS
Then I followed this recommended installation method and this documentation to install Theano as it's capable of operating on my graphics card in comparison to TensorFlow. I created .theanorc file
[global]
device = cuda0
floatX = float32
[cuda]
root=/usr/local/cuda-6.5/bin/
[dnn]
include_path = /usr/local/cuda-6.5/include/
library_path = /usr/local/cuda-6.5/lib64/
I also exported proper variables to .profile:
export PATH=/usr/local/cuda-6.5/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-6.5/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
However when I try to run this simple test script:
from theano import function, config, shared, tensor
import numpy
import time
vlen = 10 * 30 * 768 # 10 x #cores x # threads per core
iters = 1000
rng = numpy.random.RandomState(22)
x = shared(numpy.asarray(rng.rand(vlen), config.floatX))
f = function([], tensor.exp(x))
print(f.maker.fgraph.toposort())
t0 = time.time()
for i in range(iters):
r = f()
t1 = time.time()
print("Looping %d times took %f seconds" % (iters, t1 - t0))
print("Result is %s" % (r,))
if numpy.any([isinstance(x.op, tensor.Elemwise) and
('Gpu' not in type(x.op).__name__)
for x in f.maker.fgraph.toposort()]):
print('Used the cpu')
else:
print('Used the gpu')
I receive the following error:
ERROR (theano.gpuarray): Could not initialize pygpu, support disabled
Traceback (most recent call last):
File "/home/kuba/anaconda3/lib/python3.6/site-packages/theano/gpuarray/__init__.py", line 227, in <module>
use(config.device)
File "/home/kuba/anaconda3/lib/python3.6/site-packages/theano/gpuarray/__init__.py", line 214, in use
init_dev(device, preallocate=preallocate)
File "/home/kuba/anaconda3/lib/python3.6/site-packages/theano/gpuarray/__init__.py", line 99, in init_dev
**args)
File "pygpu/gpuarray.pyx", line 651, in pygpu.gpuarray.init
File "pygpu/gpuarray.pyx", line 587, in pygpu.gpuarray.pygpu_init
pygpu.gpuarray.GpuArrayException: b'Could not find symbol "cuDevicePrimaryCtxGetState": /usr/lib/libcuda.so.1: undefined symbol: cuDevicePrimaryCtxGetState'
I don't understand this error because in the Nvidia's documentation this function crearly exists. Does anyone have any clue? Can the problem be that I'm using python 3.6 while in the aforementioned documentation there's < sign before 3.6? Is any o the paths wrong?
