I purchased a smart card reader, zoweetek 12026-1, for which i will need to install pcsc and ccid drivers. I have successfully install pcsc-lite-1.8.6 but when i tried to install ccid-1.4.5-alcor i got the following error during ./configure.
Both drivers were downloaded from the zoweetek website
 ./configure
 bash: ./configure: Permission denied
which i "solved" by chmod +x configure
But when I ran make I got the following error
make[2]: Entering directory '/home/matt/9540-V2/ccid-1.4.5.1 alcor/examples'
  CC     scardcontrol-scardcontrol.o
scardcontrol.c: In function ‘main’:
scardcontrol.c:754:5: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
     (void)fgets(in, sizeof(in), stdin);
scardcontrol.c: At top level:
scardcontrol.c:816:1: fatal error: opening dependency file
.deps/scardcontrol-scardcontrol.Tpo: Permission denied  } /* main */
compilation terminated.
Makefile:322: recipe for target 'scardcontrol-scardcontrol.o' failed
make[2]: *** [scardcontrol-scardcontrol.o] Error 1
make[2]: Leaving directory '/home/matt/9540-V2/ccid-1.4.5.1-alcor/examples'
Makefile:345: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/matt/9540-V2/ccid-1.4.5.1-alcor'
Makefile:274: recipe for target 'all' failed
make: *** [all] Error 2
And as a consequence of this, make install didn't work either.
I tried to find a newer one (mainly on GitHub) but didn't and since I'm not even sure about what the error message means, I thought it would be better to ask before I start to messing up my Ubuntu installation.
requested lsusb -t output
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
        |__ Port 1: Dev 29, If 0, Class=Human Interface Device,       Driver=usbhid, 1.5M
        |__ Port 1: Dev 29, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
        |__ Port 4: Dev 32, If 0, Class=Chip/SmartCard, Driver=, 12M
        |__ Port 6: Dev 5, If 2, Class=Vendor Specific Class, Driver=, 12M
        |__ Port 6: Dev 5, If 0, Class=Wireless, Driver=btusb, 12M
        |__ Port 6: Dev 5, If 3, Class=Application Specific Interface, Driver=, 12M
        |__ Port 6: Dev 5, If 1, Class=Wireless, Driver=btusb, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
        |__ Port 4: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M
        |__ Port 4: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
installed the suggested package, but i recieved the following error msg in the terminal:
Gdk-Message: Window 0x56282676daf0 is a temporary window without parent, application will not be able to position it on screen.
(cardpeek:16708): Gdk-CRITICAL **: xdg_popup_configure: assertion 'impl->transient_for' failed
Gdk-Message: Window 0x5628267afc80 is a temporary window without parent, application will not be able to position it on screen.
seems like two times the same messages.. which i indeed get after running cardpeek only once!
