I have following issue: I've purchased dell xps 13 9360 (i7 7-th gen) with 4k (3200x1800) monitor, ubuntu gnome 17.10 installed on it, and want to plug my external HD monitor (1920x1080) using hdmi (type-c -> HDMI) cable. The issue I'm falling in is that, on the external monitor icons, windows and everything is scaled up.
I've searched through the similar problems and there were "solutions", using xrandr, or change window scale factor using dconf editor etc. As a result nothing has worked, but I hope that there may be some updates.
So please share your thoughts or solutions (if you have one), since I know that there should be some solution, because it works on windows 10, pretty nice. But I'm not windows user, so I would like to make my ubuntu behave well and get windows-like behavior.
if extra details are required, please ask.
Just in case you haven't already tried this - go into System Settings, click on Screen Display and you'll have the option to change the Resolution (select appropriate screen first) then click Apply. This also has the effect of making windows and icons bigger or smaller. Experiment with that for a while. I'm sure it's the same as on my 16.04.
Bob
  • 61
The problem is not UBUNTU it is more than likely an issue with your TV/Monitor. Sounds like you are having the same type of problem I was just having. Go into the settings on your TV/MONITOR And follow the steps HERE >> How do I fix overscan on my HDMI HDTV? The problem is called "overscan"
