-1
I have a fresh install of ubuntu 17.10 .. After installation, I was able to browse the internet, but 1 day later, and even though wi-fi appears listed as working, it is not.
I've searched around for some solution to this and have seen that I should run
gksudo gedit /etc/NetWorkManager/NetworkManger.conf
and make changes there.. however, gksudo is not something which comes with 17.10, I think, and I can't install it as no internet..
Is there a work around for this problem?
And since this is apparently a bug from 17.04 (?) is it not fixed in 17.10?
derHugo
  • 3,376
  • 34
  • 52
first of all try
ping 192.168.1.1
or if you use a public wi-fi replace the 192.168.1.1 with your modem address
then if the packets lost your modem has problem
but if your modem is right try
ping 8.8.8.8
if packets back correctly open your terminal (with ctrl+alt+t or typing terminal in your dash) and write sudo vim /etc/resolve.conf (i use vim you can use your editor but it is better that your editor hasn't gui like gedit) and then type your password and replace the ip address next of the nameserver with 8.8.8.8 and then type
you can test this with 4.2.2.4 or other dns address
and then ask your isp maybe they have a problem
by the way if you install tor purge it by sudo apt purge tor and then type sudo systemctl restart NetworkManager.service maybe you can't install tor correctly
