-1
I tried installing qt*, qt-sdk, qt5* and qt4* but none of them will even try to do anything besides vomiting errors all over the system! I'm trying to use VLC and VirtualBox but VLC complains about:
[0000562c635bed38] skins2 interface error: no suitable dialogs provider found (hint: compile the qt4 plugin, and make sure it is loaded properly)
[0000562c635bed38] skins2 interface error: cannot instantiate qt4 dialogs provider
and then VLC drops to a totally useless shell
And VirtualBox throws
VirtualBox: supR3HardenedMainGetTrustedMain: dlopen("/usr/lib/virtualbox/VirtualBox.so",) failed: libQt5Core.so.5: cannot open shared object file: No such file or directory
and won't even open
What's the problem and how can I fix it?
PS: I have all the deps for all the programs!
On a working system:
$ dpkg -S /usr/lib/virtualbox/VirtualBox.so
virtualbox-qt: /usr/lib/virtualbox/VirtualBox.so
The missing file /usr/lib/virtualbox/VirtualBox.so is provided by the virtualbox-qt package.
Let's take a look at the reverse dependencies of that package:
$ apt rdepends virtualbox-qt
virtualbox-qt
Reverse Depends:
  Recommends: virtualbox (= x.x.x.x)
So if you installed virtualbox from the Ubuntu repositories, and if it installed properly, apt would also have installed virtualbox-qt automatically.
If you installed VirtualBox from the Ubuntu repositories, and do not recall any error messages, then uninstall virtualbox, then run sudo apt autoremove, then reinstall using sudo apt install virtualbox. Pay close attention to any error messages. Check that among the dependency packages installed should be virtualbox-qt.
If you installed VirtualBox some other way, then search the existing body of broken non-Ubuntu vbox install questions on AskUBuntu. Consider uninstalling your unsupported version and installing the Ubuntu way.
user535733
  • 68,493
