I've downloaded the MEGAsync's debian package and tried to install on Ubuntu 16.04 with:
sudo dpkg -i mega.deb
But it throws this error:
Selecting previously unselected package megasync.
(Reading database ... 204976 files and directories currently installed.)
Preparing to unpack megasync-xUbuntu_16.10_amd64.deb ...
Unpacking megasync (3.5.3-2.1) ...
dpkg: dependency problems prevent configuration of megasync:
 megasync depends on libcrypto++6; however:
  Package libcrypto++6 is not installed.
 megasync depends on libqt5core5a (>= 5.6.0~beta); however:
  Version of libqt5core5a:amd64 on system is 5.5.1+dfsg-16ubuntu7.5.
 megasync depends on libqt5svg5 (>= 5.6.0~beta); however:
  Version of libqt5svg5:amd64 on system is 5.5.1-2build1.
dpkg: error processing package megasync (--install): dependency problems - leaving unconfigured Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ... Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ... Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for mime-support (3.59ubuntu1) ... Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ... Errors were encountered while processing: megasync
Then I tried sudo apt -f install to try to fix these missing dependencies and got this:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages will be REMOVED:
  megasync
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 8.368 kB disk space will be freed.
Do you want to continue? [Y/n]
How can I make it fix the dependencies and not remove MEGAsync?
Also tried sudo apt -y install ./megasync-xUbuntu_16.10_amd64.deb and got:
Note, selecting 'megasync' instead of './megasync-xUbuntu_16.10_amd64.deb'
The following packages have unmet dependencies: megasync : Depends: libcrypto++6 but it is not installable Depends: libqt5core5a (>= 5.6.0~beta) but 5.5.1+dfsg-16ubuntu7.5 is to be installed Depends: libqt5svg5 (>= 5.6.0~beta) but 5.5.1-2build1 is to be installed E: Unable to correct problems, you have held broken packages.
Kulfy
  • 18,154
s3voch7
  • 435
You can simply double click the file via GUI after you have made it executable. This is the fastest and hassle free option you can choose, it lets the system handle the dependencies. If you insist on GUI solution use gdebi for installing which does the same. So in your situation, let sudo apt install -f remove it and then do the following.
# get the right package for your Ubuntu version 16.04 if this step fails
# because you not have 'wget' installed do 'sudo apt install wget' and retry
wget https://mega.nz/linux/MEGAsync/xUbuntu_16.04/amd64/megasync-xUbuntu_16.04_amd64.deb
#update the package archives
sudo apt update
#if the next step tells you that gdebi is already installed skip to the line after that
sudo apt install gdebi
# installing it with gdebi
sudo gdebi megasync-xUbuntu_16.04_amd64.deb
This should install all the necessary dependencies and the package itself.
Videonauth
  • 33,815
Download packages from official website: https://mega.co.nz/#sync!linux
Type:
sudo dpkg -i megasync-xUbuntu_20.04_amd64.deb
Note: version of package may vary
Then Type:
sudo apt-get -f install
Note: Allow and type 'y' to remove additional disk space
Now Type:
Type megasync to launch application
All I had to do was
sudo apt-get install ~/Downloads/megasync-xUbuntu_18.04_amd64.deb
and apt resolved and installed the dependencies for me.
See also How to install a deb file on unix.se.
lucidbrot
  • 1,461
  • 41
