I have two NIC both connected to private networks one that goes to a dead end network and the other that can get to the internet through NAT.
When I bring up both the defaut route gets switched to the network that goes nowhere and none of the networking works anymore.
I've tried
routes:
 - to: 0.0.0.0/0
 via: <gateway address>
 metric: 1
from the freaking man page and netplan generate return unknown key routes
Got to love it when the documentation is evidently wrong.
Anyone know how I tell netplan which nic to use for the internet? Set a default route?
Very frustrating.
thanks.
EDIT: Okay... appears I've figured it out. Routes are associated with the interfaces rather than being global. As in...
ethernets:
  enp0:
    addresses: [192.168.0.128/24]
    gateway4: 192.168.0.1
    nameservers:
      addresses: [8.8.8.8,8.8.4.4]
    routes:
     - to: <network>
     metric: 1
  enp1:
   <etc...>
    routes:
     - to: <network>
     metric: 5
At least generate doesn't throw errors and the routes apper to change.
Networklackey
  • 31
As you stated in your question, the netplan man page is wrong. In the example in the man page routes are incorrectly placed on the same level as ethernets:
network:
  version: 2
  renderer: NetworkManager
  ethernets:
    id0:
      match:
        macaddress: 00:11:22:33:44:55
      wakeonlan: true
      dhcp4: true
      addresses:
      - 192.168.14.2/24
  routes:
  - to: 0.0.0.0/0
    via: 11.0.0.1
    metric: 3
The correct way is to place the routes under the interface that the routes go via, for example:
network:
  ethernets:
    id0:
      addresses:
      - 10.0.0.2/24
      routes:
      - to: 192.168.0.0/16
        via: 10.0.0.1
Bjorn
  • 163
[SOLUTION} Sort of...
The netplan routing I put in the question is correct and works. My problem turns out to be with Virtualbox's networking being unstable. It will work fine a one point and then will fail for no apparent reason on the next re-boot.
Time to try VMPlayer.
Networklackey
  • 31
Apparently, I didn't provide my answer to this in the proper way... allow me to correct that.
ethernets:
enp0:
    nameservers:
    routes:
     - to: <network>
     metric: 1
  enp1:
   <etc...>
    routes:
     - to: <network>
     metric: 5
At least generate doesn't throw errors and the routes appear to change.
-j
Networklackey
  • 31
