I had amdgpu-pro 17.40 installed and running fine but had some issues with a specific display (Dell U3014) not working over displayport. I opened a ticket with AMD and they suggested an update to amdgpu-pro 17.50.
Running the installer for amdgpu-pro 17.50 failed and has broken package manager such that I can not install or uninstall anything. I have reached out to AMD for help but have not gotten any response in 5 days...simply that they are still looking into it.
The results of install script and attempts to fix are:
./amdgpu-pro-install
[sudo] password for xxxx:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
amdgpu : Depends: amdgpu-core (= 17.50-511655) but it is not going to be installed
Depends: amdgpu-dkms (= 17.50-511655) but it is not going to be installed
Depends: libdrm2-amdgpu (= 1:2.4.82-511655) but it is not going to be installed
amdgpu-lib32 : Depends: libdrm2-amdgpu:i386 (= 1:2.4.82-511655)
glamor-amdgpu : Depends: amdgpu-core but it is not going to be installed
Depends: libdrm2-amdgpu but it is not going to be installed
gst-omx-amdgpu : Depends: amdgpu-core but it is not going to be installed
ids-amdgpu : Depends: amdgpu-core but it is not going to be installed
libdrm-amdgpu-amdgpu1:i386 : Depends: libdrm2-amdgpu:i386 (= 1:2.4.82-511655) but it is not going to be installed
libdrm-amdgpu-amdgpu1 : Depends: libdrm2-amdgpu (= 1:2.4.82-511655) but it is not going to be installed
libegl1-amdgpu-mesa:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
Depends: amdgpu-core:i386
libegl1-amdgpu-mesa : Depends: libdrm2-amdgpu but it is not going to be installed
libgbm1-amdgpu:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
libgbm1-amdgpu : Depends: libdrm2-amdgpu but it is not going to be installed
libgl1-amdgpu-mesa-dri:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
libgl1-amdgpu-mesa-dri : Depends: libdrm2-amdgpu but it is not going to be installed
libgl1-amdgpu-mesa-glx:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
libgl1-amdgpu-mesa-glx : Depends: libdrm2-amdgpu but it is not going to be installed
libglapi-amdgpu-mesa:i386 : Depends: amdgpu-core:i386
libglapi-amdgpu-mesa : Depends: amdgpu-core but it is not going to be installed
libllvm5.0-amdgpu:i386 : Depends: amdgpu-core:i386
libllvm5.0-amdgpu : Depends: amdgpu-core but it is not going to be installed
libwayland-amdgpu-client0:i386 : Depends: amdgpu-core:i386
libwayland-amdgpu-client0 : Depends: amdgpu-core but it is not going to be installed
libwayland-amdgpu-server0:i386 : Depends: amdgpu-core:i386
libwayland-amdgpu-server0 : Depends: amdgpu-core but it is not going to be installed
libxatracker2-amdgpu:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
libxatracker2-amdgpu : Depends: libdrm2-amdgpu but it is not going to be installed
mesa-amdgpu-omx-drivers : Depends: libdrm2-amdgpu but it is not going to be installed
mesa-amdgpu-vdpau-drivers:i386 : Depends: libdrm2-amdgpu:i386 but it is not going to be installed
mesa-amdgpu-vdpau-drivers : Depends: libdrm2-amdgpu but it is not going to be installed
xserver-xorg-amdgpu-video-amdgpu : Depends: amdgpu-core but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And then, attempting to fix:
sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
cinnamon-desktop-data gyp javascript-common libcinnamon-desktop4 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore libssl-dev libssl-doc
libuv1 libuv1-dev linux-headers-4.10.0-28 linux-headers-4.10.0-28-generic linux-image-4.10.0-28-generic linux-image-extra-4.10.0-28-generic
node-abbrev node-ansi node-ansi-color-table node-archy node-async node-block-stream node-combined-stream node-cookie-jar node-delayed-stream
node-forever-agent node-form-data node-fstream node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-inherits
node-ini node-json-stringify-safe node-lockfile node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
node-normalize-package-data node-npmlog node-once node-osenv node-qs node-read node-read-package-json node-request node-retry node-rimraf
node-semver node-sha node-sigmund node-slide node-tar node-tunnel-agent node-underscore node-which zlib1g-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
amdgpu-dkms libdrm2-amdgpu:i386 libdrm2-amdgpu
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 56 not upgraded.
46 not fully installed or removed.
Need to get 0 B/5,638 kB of archives.
After this operation, 127 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 file:/var/opt/amdgpu-pro-local ./ amdgpu-dkms 17.50-511655 [5,578 kB]
Get:2 file:/var/opt/amdgpu-pro-local ./ libdrm2-amdgpu 1:2.4.82-511655 [29.5 kB]
Get:3 file:/var/opt/amdgpu-pro-local ./ libdrm2-amdgpu 1:2.4.82-511655 [30.5 kB]
(Reading database ... 334828 files and directories currently installed.)
Preparing to unpack .../amdgpu-dkms_17.50-511655_all.deb ...
Unpacking amdgpu-dkms (17.50-511655) ...
dpkg: error processing archive /var/opt/amdgpu-pro-local/./amdgpu-dkms_17.50-511655_all.deb (--unpack):
trying to overwrite '/etc/modprobe.d/blacklist-radeon.conf', which is also in package amdgpu-pro-dkms 17.40-492261
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack .../libdrm2-amdgpu_2.4.82-511655_amd64.deb ...
Unpacking libdrm2-amdgpu:amd64 (1:2.4.82-511655) ...
dpkg: error processing archive /var/opt/amdgpu-pro-local/./libdrm2-amdgpu_2.4.82-511655_amd64.deb (--unpack):
trying to overwrite '/lib/udev/rules.d/91-amdgpu-pro-modeset.rules', which is also in package libdrm2-amdgpu-pro:i386 1:2.4.82-492261
Preparing to unpack .../libdrm2-amdgpu_2.4.82-511655_i386.deb ...
Unpacking libdrm2-amdgpu:i386 (1:2.4.82-511655) ...
dpkg: error processing archive /var/opt/amdgpu-pro-local/./libdrm2-amdgpu_2.4.82-511655_i386.deb (--unpack):
Processing triggers for libc-bin (2.23-0ubuntu9) ...
I would appreciate any ideas/guidance on how to fix this issue. At this point apt cant install or uninstall anything at all.
