Ubuntu 17.10 (GNU/Linux 4.13.0-16-generic x86_64)
After installing java with the command:
sudo apt install openjdk-8-jdk-headless
I have java version 8u151
But because of the bug (https://bugs.openjdk.java.net/browse/JDK-8189789) I need to install the previous update of Java 8 u144 or u131 whatever.
To see available versions:
$ apt-cache policy openjdk-8-jdk-headless
openjdk-8-jdk-headless:
  Installed: (none)
  Candidate: 8u151-b12-0ubuntu0.17.10.2
  Version table:
     8u151-b12-0ubuntu0.17.10.2 500
        500 http://us.archive.ubuntu.com/ubuntu artful-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu artful-security/main amd64 Packages
     8u144-b01-2 500
        500 http://us.archive.ubuntu.com/ubuntu artful/main amd64 Packages
And when I try to install
$ sudo apt install  openjdk-8-jdk-headless=8u144-b01-2
Reading package lists... Done
Building dependency tree
 openjdk-8-jdk-headless : Depends: openjdk-8-jre-headless (= 8u144-b01-2) but 8u151-b12-0ubuntu0.17.10.2 is to be installed
Here I stucked.
The question: How to install exact update of OpenJDK 8?
daggett
  • 163
You can use aptitude and the following command:
sudo aptitude install openjdk-8-jdk-headless=8u144-b01-2
During the process, Aptitude will ask to choose one of the variants to resolve this problem and it's needed to choose an installation of the previous version of the openjdk-8-jre-headless package in this case.
Or you can manually install the previous version of the packages:
sudo apt install openjdk-8-jre-headless=8u144-b01-2
