I was going some testing and decided to delete some library files in
/usr/lib/x86_64-linux-gnu/
(Horrible idea I know) The side effect of deleting those files is that I am unable to open the gnome or unity control center for Ubuntu. When I open the control center by running unity-control-center -v
/usr/lib/x86_64-linux-gnu/libwebkit2gtk-4.0.so.37: undefined symbol: sqlite3_errstr
Failed to load module: /usr/lib/x86_64-linux-gnu/unity-control-center-1/panels/libinfo.so
** (unity-control-center:9666): DEBUG: Enabling debugging
I have everywhere for this error and tried reinstalling many many diffrent libs but none seem to work. This is different from other questions because the libraries can be restored by installing the right packages Using Ubuntu 16.04.3 LTS
MSPO
Two options here:
  1. You should try to fix this with debsums. You can find missed files with it and reinstall their packages with the following commands:
    sudo apt-get install debsums
    sudo debsums_init
    sudo debsums --changed --silent
    then reinstall mentioned packages manually with
    sudo apt-get -f install
  2. Or try to find all packages, which have files in /usr/lib/x86_64-linux-gnu/ with dpkg -S /usr/lib/x86_64-linux-gnu/ or combined with re-installation
    sudo apt-get install --reinstall `dpkg -S /usr/lib/x86_64-linux-gnu/ \
    | sed 's/,/ /g' | head -c-28`
muru
  • 207,228
N0rbert
  • 103,263
