Ubuntu 10.04.
After an update, I get a red warning icon in the system tray, warning about an error: broken count >0
Opening Update manager, I see that the broken package is linux-headers-2.6.32-38 (new install)
Trying to use the update manager, I get a further error message: You have 1 broken package on your system! Use the "Broken" filter to locate it.
and then:
E: /var/cache/apt/archives/linux-headers-2.6.32-38_2.6.32-38.83_all.deb: unable to create `/usr/src/linux-headers-2.6.32-38/arch/arm/mach-netx/include/mach/vmalloc.h.dpkg-new' (while processing `./usr/src/linux-headers-2.6.32-38/arch/arm/mach-netx/include/mach/vmalloc.h')
I tried apt-get clean as suggested in another question on this site, and tried reinstalling the package in Synaptic.
One option I have not tried is simply to restart, but I don't dare to in case I can't reboot back into Ubuntu.
I have also tried apt-get install --fix-broken and I get the following:
The following extra packages will be installed:
The following NEW packages will be installed
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0B/9,937kB of archives.
After this operation, 76.2MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 589950 files and directories currently installed.)
Unpacking linux-headers-2.6.32-38 (from .../linux-headers-2.6.32-38_2.6.32-38.83_all.deb) ...
dpkg: error processing /var/cache/apt/archives/linux-headers-2.6.32-38_2.6.32-38.83_all.deb (--unpack):
unable to create `/usr/src/linux-headers-2.6.32-38/arch/arm/mach-nomadik/Makefile.boot.dpkg-new' (while processing `./usr/src/linux-headers-2.6.32-38/arch/arm/mach-nomadik/Makefile.boot'): No space left on device
No apport report written because the error message indicates a disk full error
        dpkg-deb: subprocess paste killed by signal (Broken pipe)
geoffrey
  • 2,439
Looks like your drive is full and has no free space. Try moving some unwanted files like music, videos, documents and such to another partition. And then try the sudo apt-get install --fix-broken . You need to move about 76.2 MB of stuff to be exact, but might as well move what you can.
After that your system should be back to normal with no broken packages :)
