I am facing a problem with rpcbind. the service is not starting after the reboot even after enabling the service.
I get the following output when i run systemctl status rpcbind just after reboot.
root@ubuntu:~# systemctl status rpcbind
● rpcbind.service - RPC bind portmap service
Loaded: loaded (/lib/systemd/system/rpcbind.service; indirect; vendor preset: enabled)
Drop-In: /run/systemd/generator/rpcbind.service.d
└─50-rpcbind-$portmap.conf
Active: inactive (dead)
root@ubuntu:~#
And if i start the service systemctl start rpcbind the service will start.
And when i enable the service with systemctl enable rpcbind command i get the following output.
root@ubuntu:~# systemctl enable rpcbind
Synchronizing state of rpcbind.service with SysV init with /lib/systemd/systemd-sysv-install...
Executing /lib/systemd/systemd-sysv-install enable rpcbind
Output of cat /lib/systemd/system/rpcbind.service
root@ubuntu:~# cat /lib/systemd/system/rpcbind.service
[Unit]
Description=RPC bind portmap service
After=systemd-tmpfiles-setup.service
Wants=remote-fs-pre.target
Before=remote-fs-pre.target
Requires=rpcbind.socket
DefaultDependencies=no
[Service]
Environment="OPTIONS=-w"
ExecStart=/sbin/rpcbind -f $OPTIONS
EnvironmentFile=-/etc/rpcbind.conf
EnvironmentFile=-/etc/default/rpcbind
Type=notify
KillMode=process
Restart=on-failure
[Install]
Also=rpcbind.socket
But the service still not enabling after the reboot.
Can anybody help please ?
