Ubuntu 16.04 LTS was damaged during an upgrade and it can't be fixed. I need to save all my files in the disk in another disk.
When I log in as root during recovery mode, I see all my files there and I can read them without issue.
However when I connect a new disk (usb or hard disk) via USB this is not visible in the media folder, therefore I have no way to copy the files somewhere else, what should be done so that I can connect an external disk and copy all the contents that I need into the other disk?
NetNeutrality
  • 51
Try the following to mount an external in recovery mode:
  1. Plugin the external HDD, then run sudo fdisk -l to know the partition information.
  2. Create a mount point:
    sudo mkdir /mnt/usb
  3. Now mount it at the location in step 2:
    sudo mount -t <file_type> /dev/sdb1 /mnt/usb -o umask=000
  4. Now you should be able to move the files over.
Note"
  • /dev/sdb1 is imaginary yours could be /dev/sdc1
  • umask=000 makes it writable
Source:
https://ubuntuforums.org/showthread.php?t=1165891
George Udosen
  • 37,534
use a live installation cd boot it then copy all the contents from your bricked ubuntu system to pendrive easy
aman5319
  • 239
