When I plug-in or unplug my charger on my MSI PE607Rd, Ubuntu freezes.
How should I proceed?
I too had that problem.
First, I enabled battery icon in my laptop by using dconf editor.
Also I had shutdown freeze problem and to overcome that I changed the /etc/default/grub/ setting and set apci=force. This resolved that problem.
And, when I finally restarted, both of the problems were resolved and also the plug in or out charger freeze problem.
Try enabling the battery icon and in grub, set apci=force.
This may help you. Now it's working well for me.
udevadm monitor to decipher errors unplugging ACFirst boot your computer with AC plugged in. Then type sudo udevadm monitor wait a second and unplug the AC. Your screen will look something like this:
$ sudo udevadm monitor
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[5888.768785] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/ACPI0003:00/power_supply/ACAD (power_supply)
KERNEL[5888.799754] add /module/thinkpad_acpi (module)
UDEV [5888.800544] add /module/thinkpad_acpi (module)
KERNEL[5888.824515] remove /module/thinkpad_acpi (module)
UDEV [5888.824827] remove /module/thinkpad_acpi (module)
UDEV [5889.752862] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/ACPI0003:00/power_supply/ACAD (power_supply)
KERNEL[5889.804222] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/PNP0C0A:03/power_supply/BAT1 (power_supply)
UDEV [5889.805394] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/PNP0C0A:03/power_supply/BAT1 (power_supply)
The question is where did it stop in the above list?
udevadm monitor to decipher errors plugging in ACNext reboot your machine whilst it's running on battery. Start sudo udevadm monitor again. Plug in your AC and your screen will look something like this:
-KERNEL[5905.564769] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/ACPI0003:00/power_supply/ACAD (power_supply)
KERNEL[5905.597141] add /module/thinkpad_acpi (module)
UDEV [5905.598205] add /module/thinkpad_acpi (module)
KERNEL[5905.624567] remove /module/thinkpad_acpi (module)
UDEV [5905.625432] remove /module/thinkpad_acpi (module)
KERNEL[5906.632639] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/PNP0C0A:03/power_supply/BAT1 (power_supply)
UDEV [5906.635327] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/PNP0C0A:03/power_supply/BAT1 (power_supply)
UDEV [5906.716708] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/ACPI0003:00/power_supply/ACAD (power_supply)
The second question is when did your machine lock up in the above list?
gedit /var/log/syslog to review error messagesNow reboot your machine whilst it is still plugged in. Log on again and type gedit /var/log/syslog.
Scroll through the list to the time when your machine crashed looking for error messages:
Dec 15 15:43:34 alien upowerd[1685]: (upowerd:1685): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0004/0003:046D:2010.0007/power_supply/hidpp_battery_0
Dec 15 15:43:39 alien kernel: [ 5800.616352] acpi INT3400:00: Unsupported event [0x86]
Dec 15 15:43:46 alien kernel: [ 5807.735823] snd_hda_codec_ca0132 hdaudioC0D0: ca0132 DSP downloaded and running
Dec 15 15:43:46 alien kernel: [ 5807.912730] acpi INT3400:00: Unsupported event [0x86]
Dec 15 15:45:07 alien kernel: [ 5888.842935] ata2.00: exception Emask 0x10 SAct 0x0 SErr 0x50000 action 0xe frozen
Dec 15 15:45:07 alien kernel: [ 5888.842938] ata2.00: irq_stat 0x00400000, PHY RDY changed
Dec 15 15:45:07 alien kernel: [ 5888.842939] ata2: SError: { PHYRdyChg CommWake }
Dec 15 15:45:07 alien kernel: [ 5888.842942] ata2.00: failed command: IDENTIFY DEVICE
Dec 15 15:45:07 alien kernel: [ 5888.842944] ata2.00: cmd ec/00:01:00:00:00/00:00:00:00:00/40 tag 12 pio 512 in
Dec 15 15:45:07 alien kernel: [ 5888.842944] res 50/00:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
Dec 15 15:45:07 alien kernel: [ 5888.842946] ata2.00: status: { DRDY }
Dec 15 15:45:07 alien kernel: [ 5888.842949] ata2: hard resetting link
Dec 15 15:45:08 alien kernel: [ 5889.554959] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 15 15:45:08 alien kernel: [ 5889.557410] ata2.00: configured for UDMA/133
Dec 15 15:45:08 alien kernel: [ 5889.567686] ata2: EH complete
Dec 15 15:45:08 alien kernel: [ 5889.675349] acpi INT3400:00: Unsupported event [0x86]
Dec 15 15:45:24 alien kernel: [ 5906.215059] snd_hda_codec_ca0132 hdaudioC0D0: ca0132 DSP downloaded and running
Dec 15 15:45:25 alien kernel: [ 5906.503964] acpi INT3400:00: Unsupported event [0x86]
Dec 15 15:47:17 alien kernel: [ 6018.982028] ata2.00: exception Emask 0x10 SAct 0x0 SErr 0x50000 action 0xe frozen
Dec 15 15:47:17 alien kernel: [ 6018.982038] ata2.00: irq_stat 0x00400000, PHY RDY changed
Dec 15 15:47:17 alien kernel: [ 6018.982044] ata2: SError: { PHYRdyChg CommWake }
Dec 15 15:47:17 alien kernel: [ 6018.982048] ata2.00: failed command: CHECK POWER MODE
Dec 15 15:47:17 alien kernel: [ 6018.982057] ata2.00: cmd e5/00:00:00:00:00/00:00:00:00:00/00 tag 5
Dec 15 15:47:17 alien kernel: [ 6018.982057] res 50/00:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
Dec 15 15:47:17 alien kernel: [ 6018.982062] ata2.00: status: { DRDY }
Dec 15 15:47:17 alien kernel: [ 6018.982070] ata2: hard resetting link
Dec 15 15:47:18 alien kernel: [ 6019.697995] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 15 15:47:18 alien kernel: [ 6019.700625] ata2.00: configured for UDMA/133
Dec 15 15:47:18 alien udisksd[2389]: Error performing housekeeping for drive /org/freedesktop/UDisks2/drives/HGST_HTS721010A9E630_JR10004M303XVF: Error updating SMART data: Error sending ATA command CHECK POWER MODE: Unexpected sense data returned:#0120000: 70 00 05 00 00 00 00 0a 00 50 00 00 21 04 00 00 p........P..!...#0120010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................#012 (g-io-error-quark, 0)
Dec 15 15:47:18 alien kernel: [ 6019.710827] ata2: EH complete
In my case I see error messages but my laptop didn't lock up. Because I have a long list of error messages I already need to clean up and because I never run on the laptop on battery, I'll just ignore these errors.
Google search is a great help in finding other people with the same problem and solutions to it.
