When I use the command sudo apt-get update I get the following error
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Whats the meaning of this?
user227
seems like your apt is locked with another process. you can view which process is using apt with this command:
lsof /var/lib/dpkg/lock
to unlock it run this command:
sudo rm /var/lib/dpkg/lock
mehrdadep
  • 381
some Apt process is running on. You first need to close it.
use this command to see if there is any apt processors running:-
ps aux | grep apt
if you found it then u can kill it with its PID
kill -9 PID
You can use sudo lsof /var/lib/dpkg/lock to see what is using the lock
jorion@home{~}:$ sudo lsof /var/lib/dpkg/lock
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
      Output information may be incomplete.
COMMAND   PID USER   FD   TYPE DEVICE SIZE/OFF   NODE NAME
synaptic 7061 root   20uW  REG   8,54        0 131016 /var/lib/dpkg/lock
in this example its synaptic
John Orion
  • 2,871
-2
Try this command to abort apt-get process:
killall apt
May can help if other app used apt. after this command may you get some error to run apt again, if is, so run:
apt update -f
