I'd like to reduce the screen brightness on my Lubuntu desktop (Ubuntu 16.04).
I googled but could not find any soluton that works. (like using xbacklight -set 45 command.
Appreciate a simple working solution.
execute any of these inside root terminal
echo 1 > /sys/class/backlight/acpi_video0/brightness
sudo echo 1 | sudo tee /sys/class/backlight/acpi_video0/brightness
if /sys/class/backlight/ folder is empty
nano /boot/grub/grub.cfg
add this to kernel line
acpi_osi=Linux acpi_backlight=vendor
or
nano /etc/default/grub
see a line like GRUB_CMDLINE_LINUX_DEFAULT and add
save and run
update-grub
to save changes to grub
reboot
I use Lubuntu with an Nvidia graphics card. The brightness setting is in the "NVIDIA X Server Settings" app. It's kind of buried though - you have to select the "HDMI-0" from the menu on the left, and then click the "color correction" tab.
You don't mention your graphics hardware, but if you don't use Nvidida, perhaps the setting is related to your graphics card as well.
