21
Is there any cut command to cut based on a word eg :
171212 16082784       6264 XXX     xxxxxxxx Transaction XXXXX abend ABCD. The task has terminated abnormally because of a program check. 16:08:27
I want the output as :
How to approach?
muru
  • 207,228
Anony
  • 803
5 Answers5
29
I suggest:
awk -F 'ABCD' '{print $1 FS "."}' file
Output:
FS contains your delimiter "ABCD". "ABCD" is a regex.
Cyrus
  • 5,789
sed version:
sed 's/ABCD.*/ABCD./' input.txt
Source: https://unix.stackexchange.com/questions/257514/how-to-delete-everything-after-a-certain-pattern-or-a-string-in-a-file
awk can do the job if you provide -F flag with the word which you want to use:
$ awk -F 'test'  '{print $1;print $2}'  <<<  "onetesttwotest"
one
two
In your particular case, that would be:
$ awk -F 'ABCD' '{print $1,FS}' input.txt
Judging from your example, you're only trying to print stuff up to ABCD so deleting everything after that is also an option:
$ awk '{print substr($0,0,match($0,/ABCD/)+4);}' input.txt
grep solution:
grep -o '^.*ABCD\.' input.txt
The regular expression will match to each line that begin ^ with any character . repeated number of times * and ends with the string ABCD. The backslash \ escapes the special meaning of the dot . at the end.
The option -o will tell the grep command to print only the matched (non-empty) parts of a matching line.
pa4080
  • 30,621
cut can itself perform this job. Not based on a word, but based on . delimiter.
Use :
cut -f 1 -d '.' input.txt | xargs -I "%" echo %.
Output
rooney@bond-pc:~$ cat input.txt
rooney@bond-pc:~$
rooney@bond-pc:~$ cut -f 1 -d '.' input.txt | xargs -I "%" echo %.
xargs is used here only to append . at the end of string ABCD.
Rooney
  • 975
