I am new to Linux and I know that variations of this question have been asked before. However, none of the answers reflect what I see so I thought I'd try again from scratch,
I have installed live/persistent Ubuntu/Gnome 16.04 LTS to a USB stick using the Universal USB Installer at pendrivelinux.com
I can boot from the USB key and, using the "Try Ubuntu,,," option, get taken straight into a Gnome desktop without being asked for a password. If I log out of this session, I cannot log back in again because I don't know the password. I have searched this forum and find:
Some people have said quite categorically that the password is blank; wrong, this doesn't work.
Other people have said equally categorically that the password is "ubuntu"; wrong again, this doesn't work.
"Ubuntu" (another "definitive answer" in this forum) also doesn't work.
I have also tried, from other suggestions in this forum "utnubu", "reverse" and null. None of these works.
Help.
Please.
hwfa
Here's the actual answer. Username is ubuntu-studio and no password. Based on the above response with Lubuntu login for live session, that actually worked.
Eliah Kagan
  • 119,640
You need to set a password as soon as you login. To do this, run the following command in a terminal:
passwd
Then, press enter if it asks for the current password because it should currently be blank.
Then, type a password when it asks you to and then press enter.
Confirm the password by typing it in again when you are asked to do so and then press enter .
You should now be able to log out and then back in again using this password.
note: You may need to do this again the next time you boot up using the USB stick.
mchid
  • 44,904
  • 102
  • 162
