I'm sorry for creating this thread, but i cant solve this issue myself.
I want crontab to execute basic command "xrandr --auto"
I've created an test.sh file that looks like this.
#!/bin/bash
xrandr --auto
After I have added following line to crontab -e, I used default nano editor.
*/2 * * * * /home/dashboarduser/test.sh
Also tried like this
*/2 * * * * root /home/dashboarduser/test.sh
It does not work, I don't know why.
After some searching found this command grep CRON /var/log/syslog to see the contents of cron logfile.
Dec 12 14:06:01 : (dashboarduser) CMD (root /home/dashboarduser/test.sh # JOB_ID_1)
Dec 12 14:06:01 : (CRON) info (No MTA installed, discarding output)
If i run my script in terminal -> /home/dashboarduser/test.sh it works fine.
Thanks in advance.
dessert
  • 40,956
P75
First, check that the script is executable.
Second, try running the script yourself from the same account as cron will run it from.
The script will be executed from the user account of the crontab. So if you run crontab -e while logged in to your regular user account, all the jobs in that crontab will be run as you.
Note that if you have mail working (eg a MTA installed) on your machine you'll be emailed when a cron job emits any output (such as error messages).
thomasrutter
  • 37,804
First of all you need to install an MTA to get more input like the error message
indicates. See here on how to to this.
OR
Redirect the output of your script in some file, like it is shown here.
dessert
  • 40,956
Yeti
  • 212
  • 15
